Register to reply
Strongest to Weakest Oxidant
by Endorser
Tags: oxidant, strongest, weakest
Share this thread:
Endorser
#1
Aug19-10, 09:58 PM
P: 42
Hello All I have been given a question form my chem teacher asking to place the following; Zn, Fe, Cu, I^- in order from strongest to weakest oxidant.
I have attempted two methods to solve this question
1st using the oxidation reaction table which lists as follows:
Zn>Fe>Cu>I
2nd using reduction half-reaction table which lists as following:
Zn>Cu>2I^->Fe^2+
I am unsure what 1 to use so please help me
Thanks
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
Endorser
#2
Aug19-10, 10:43 PM
P: 42
I have the following elements Zn, I^-, Fe^3+, Cu and i would like to know how to place these in order from strongest to weakest oxidant.
Thanks
Borek
#3
Aug21-10, 02:18 AM
Admin
Borek's Avatar
P: 23,363
Check standard potential tables.
Endorser
#4
Aug21-10, 06:22 AM
P: 42
Quote Quote by Borek View Post
So is the correct answer; (strong to weak)
Fe^2+
2I^-
Cu
Zn
just want some confirmation on this
thanks
Redbelly98
#5
Aug21-10, 11:45 AM
Mentor
Redbelly98's Avatar
P: 12,064
Moderator's note: two identical threads merged into one.
Borek
#6
Aug21-10, 04:57 PM
Admin
Borek's Avatar
P: 23,363
Please list half reactions in which each given substance behaves as an oxidizer and list standard potentials of these reactions.
Endorser
#7
Aug21-10, 09:17 PM
P: 42
[QUOTE=Borek;2848106]Please list half reactions in which each given substance behaves as an oxidizer and list standard potentials of these reactions./QUOTE]
Full
Zn2+ (aq)| Zn(S) || Cu2+(aq) | Cu(S)
I2(aq) | l-(aq) ||Cu2+(aq) | Cu(S)
I2(aq) | l-(aq) || Fe3+(aq) | Fe2+(aq)
Zn2+ (aq)| Zn(S) || I2(aq) | l-(aq)
Zn2+ (aq)| Zn(S) || Fe3+(aq) | Fe2+(aq)
Fe3+(aq) | Fe2+(aq) || Cu2+(aq) | Cu(S)
Half
Oxidation
Zn(S) → Zn2+(aq) + 2e-
Cu(S) → Cu2+(aq) + 2e
2I-(aq) → I2(aq) + 2e-
Reduction
Cu2+(aq) + 2e- → Cu(S)
I2(aq) + 2e- →2I-(aq)
Fe3+(aq) +e- →Fe2+(aq)
Borek
#8
Aug22-10, 02:25 AM
Admin
Borek's Avatar
P: 23,363
Seems to me like you have listed everything just in case, as you have no idea what to look for.
I asked for half reactions, so full reactions are ruled out.
When substance acts as an oxidant (or oxidizer), what does happen to it? Does it gain, or loses electrons?
Finally, you have listed reactions, but omitted potentials, which are the most important part when looking for the answer to your question.
methods
Endorser
#9
Aug22-10, 02:38 AM
P: 42
OXI RED
Oxidation is increase Reduction is decrease
Borek
#10
Aug22-10, 03:08 AM
Admin
Borek's Avatar
P: 23,363
Redox reaction means transfer of electrons - that means one substance gains electrons, other loses them. That in turn means one substance gets reduced, while the other gets oxidized.
Now, what happens to the substance that acts as an oxidizer? If you don't know, try to analyze the situation. Imagine there two substances reacting, Ox, and Red.
Substance Ox acts as an oxidizer.
The other substance is oxidized - does it get, or lose electrons?
If so, what happened to the electrons of the Ox substance - did it get more, or lost some?
If so, was it reduced, or oxidized?
And please, try to answer these questions, and not evade the answer but saying something that is basically right but not related to the question, as you did twice already. It won't work with me.
Endorser
#11
Aug22-10, 04:13 AM
P: 42
Zn -> Zn^2+ + 2e^-
thus is has oxidized as Oxidation is gain in electrons
Borek
#12
Aug22-10, 05:17 AM
Admin
Borek's Avatar
P: 23,363
OXI RED - Oxidation is increase Reduction is decrease - in terms of oxidation number.
OIL RIG - Oxidation is Loss Reduction is Gain - in terms of electrons.
Endorser
#13
Aug23-10, 05:31 AM
P: 42
ahhhh... i c
so
Zn -> Zn^2+ + 2e^-
would be reduction due to OIL RIG
Borek
#14
Aug23-10, 06:00 AM
Admin
Borek's Avatar
P: 23,363
Yep. Now, go back and do as asked earlier.
methods
Register to reply
Related Discussions
How is gravity the weakest force? General Physics 26
Ideology: Humanity’s Weakest Link General Discussion 35
Please give me stronger oxidant than water which can't kill my body? Chemistry 2
What Is Your Strongest Emotion? Social Sciences 19
