| Thread Closed |
Force pushes and pulls two blocks at an angle |
Share Thread | Thread Tools |
| Sep24-10, 01:16 PM | #1 |
A force of 23.52 N pushes and pulls to blocks as shown in the figure below. The vertical contact surfaces between the two blocks are frictionless. The contact between the blocks and the horizontal surface has a coefficient of friction of 0.29. The acceleration of gravity is 9.8 m/s2 What is the magnitude a of the acceleration of the blocks? Answer in units of m/s2 2. Relevant equations I know its the sum of Fy=N-mg=0 => N=mg and the sum of Fx= -fk=max 3. The attempt at a solution fk=ukN=> fk=20.4624 but I do not know how to plug in Fcostheta or Fsintheta and I know those need to be used somewhere
| Sep24-10, 01:21 PM | #2 |
Create a free body diagram for each block, and then use ∑F=manet to find the resulting acceleration.
What forces are acting on each block? How can you use these forces to find the net force on the blocks in the x direction? |
| Sep24-10, 01:24 PM | #3 |
in the x direction there is fk and F... On the second block in the y direction there is Fsintheta, N, and m2g in the x direction there is fk and Fcostheta... right? |
| Sep24-10, 01:25 PM | #4 |
Mentor
| Sep24-10, 05:55 PM | #5 |
Thank you for you're help on my other problems too you're a live saver |
| Thread Closed |
| Tags |
| forces friction |
| Thread Tools | |
Similar Threads for: Force pushes and pulls two blocks at an angle
| Three blocks colliding- velocity and angle of the third, so they come to rest | Introductory Physics Homework | 0 | ||
| Two blocks touching with one applied force...how to calculate force of one on another | Introductory Physics Homework | 3 | ||
| [SOLVED] A woman pulls a suitcase..what is the angle with the horizontal? | Introductory Physics Homework | 7 | ||
| force on blocks | Introductory Physics Homework | 1 | ||
| force on two blocks | Introductory Physics Homework | 4 | ||
