Calculating Temperature Increase in Iron with Double the Molecules
  • Context: High School
  • Thread starter Thread starter JayseR
    Iron Temperature
The discussion revolves around the calculation of temperature for a second block of iron, which is stated to be double the temperature of a first block at 10 degrees Celsius. Participants explore the implications of temperature scales, particularly the Celsius and Kelvin scales, and the nature of temperature as a measure of kinetic energy.
  • Some participants assert that to find the temperature of the second block, one must convert the Celsius temperature to Kelvin, double it, and convert back to Celsius, resulting in 293 degrees Celsius.
  • Others question the necessity of using a calculator for this calculation, suggesting that it could be done logically.
  • A participant introduces the idea that the question is incomplete and depends on the observer's reference frame, implying that temperature measurements could vary based on relativistic effects.
  • Some participants discuss the linearity of temperature scales, questioning whether temperature is a linear measure of kinetic energy and how this relates to the Celsius scale.
  • There is a mention of the total kinetic energy of molecules at different temperatures, suggesting a relationship between temperature and kinetic energy distribution.
Participants generally agree on the conversion method involving Kelvin to arrive at the temperature of 293 degrees Celsius, but there are competing views regarding the necessity of this method and the nature of temperature itself. The discussion remains unresolved regarding the linearity of temperature and its implications.
Some participants express uncertainty about the assumptions underlying temperature measurements and the implications of different temperature scales. The discussion highlights the complexity of defining temperature in relation to kinetic energy and the reference frame of the observer.
JayseR
For most of you experts out there, this should be fairly simple to answer. Well, technically, all it takes is logic to answer this:
A block of Iron has a temperature of 10 degrees celsius.
There is a second block of iron, identicle to the first, that is 2x the temperature of the first block of iron.
What is the temperature of the second block of iron?
40 degrees celsius.
The Bob (2004 ©)
Using my Post 1491 analog calculator, I line up 10 degrees Celsius with the left index, move the cursor to 2 on the D scale, read 293 [/color] degrees Celsius on the Celsius scale. (select to see answer).
BobG, surely, I have no idea what you're talking about. Maybe that's because I really haven't much used calculators, least of all, the analog ones you're so fond of. Somehow, you seem to have lucked out and gotten the right answer. :wink:
BobG said:
Using my Post 1491 analog calculator, I line up 10 degrees Celsius with the left index, move the cursor to 2 on the D scale, read [deleted or otherwise it would show on this dark background] degrees Celsius on the Celsius scale.
Wow...BobG, did you really need a calculator for that? :bugeye: Your reply almost put me off attempting the teaser. :biggrin:
If BobG's answer is correct (I think it is), then you really do need a knowledge of absolute temperatures and not just logic.
Twice 283 K (10 degrees Celsius) x 2 = 566 K = 293 degrees Celsius.
Highlight the empty space above to behold my answer. :approve: :-p
The question is incompleted. It depends of the dynamic state of the observer. If an observer is attached to a reference frame traveling a speed near light speed, then the measurements would be done by means of photoelectric instruments. The thermal energy will depend on the reference frame, and so the temperature.
Sounds pretty well, isn't it?
Technically, BobG is right. If you convert 10 degrees celsius into kalven, then double that number, and convert the doubled number back into celsius, you will get bob's answer. Good job :)
Which Bob and what is the answer?
The Bob (2004 ©)
The correct answer is 293C. The absolute scate for temperature is the Kelvin scale. So to double the temperature, you must double the Kelvin temperature.
Understood. Cheers.
The Bob (2004 ©)
yuppo! that's right, and I'm prettty sure I said that BobG was right.
Sorry. :redface: :smile:
The Bob (2004 ©)
How do we know that temperature is a linear scale? If it is a measure of the kinetic energy of the molecules that make up a substance, then that energy increases as the square of the average (for some meaning of average) molecular speed.
The celsius scale is fixed at two points (0 and 100) by boiling and freezing pure water at a certain atmospheric pressure. but what shape is the line joining these points? Is it a straight line, or a parabola? In what sense is 50 degrees C 'half way' between 0C and 100C ?
I guess no one saw my solution in my previous post. :mad: :cry: I shouldn't write my answers in white next time. :smile: :-p
I saw it.
But, the use of my 1955 calculator, which you made fun of me for using, which has never had a new set of batteries installed in it, which is just now finally beginning to get that nice broken in feel to it, and which should last at least another 25 years, enabled me to get my answer in first. :biggrin:
You got to love good bamboo.
Linear in what ? Temperature is not a linear function of the RMS velocity, but is linear in the average KE.
Is it a straight line, or a parabola? [/quote]
This question doesn't make sense unless you specify what you're plotting the temperature against.
This can be answered. The total kinetic energy of 2n molecules of a thing at 50C is the same as the total KE of n molecules at 0C and n at 100C.
Thanks. I should have known that, but didn't. :smile:
  • · Replies 31 ·
  • · Replies 26 ·
