| New Reply |
"Proper distance" in GR |
Share Thread |
| Oct21-10, 09:19 PM | #69 |
"Proper distance" in GRhttp://www.mathpages.com/rr/s6-07/6-07.htm 1. Free fall from infinity with a given initial velocity V (including V=0) The coordinate velocity of a free falling particle at r, with initial velocity of V at infinity is: [tex]\frac{dr}{dt} = (1-2m/r) \sqrt{\frac{2m}{r}(1-V^2) +V^2} [/tex] The time dilation factor for the falling particle is: [tex]\frac{dt}{dtau} = \frac{1}{(1-2m/r) \sqrt{1 - V^2}} [/tex] It follows that the proper velocity of a free falling particle in terms of the proper time of the particle is: [tex]\frac{dr}{dtau} = \sqrt{\frac{2m}{r} + \frac{ V^2}{(1-V^2)}} [/tex] 2. Free fall from a given r value. The coordinate velocity of a free falling particle at r that was initially at rest at R is: [tex]\frac{dr}{dt} = \frac{(1-2m/r)}{ \sqrt{1-2m/R} } \sqrt{\frac{2m}{r} - \frac{2m}{R}} [/tex] The time dilation factor for the particle dropped from R is: [tex]\frac{dt}{dtau} = \frac{ \sqrt{1 - 2m/R}}{ (1-2m/r) } [/tex] It follows that the proper velocity of a free falling particle dropped from R in terms of the proper time of the particle is: [tex]\frac{dr}{dtau} = \sqrt{\frac{2m}{r} - \frac{2m}{R}} [/tex] 3. An linearly accelerating observer falling in the field (e.g. the magnitude of his acceleration is smaller than the inertial acceleration of the field). This is more complicated. Some equations for this situation were given in #345 of this old thread: http://www.physicsforums.com/showthr...88#post2747788 [EDIT] The equations for a particle with initial velocity V have been edited to correct a major mistake in the calculations pointed out by Passionflower. [/EDIT] |
| Oct21-10, 10:17 PM | #70 |
The proper distance between two events is equal to the 3-distance measured in a coordinate system containing a minimal geodesic in a hypersurface of simultaneity. |
| Oct21-10, 10:34 PM | #71 |
I meant to specify that a spacelike geodesic is a local minimum related to NNT paths in a coordinate system that includes that geodesic as an NNT path. This is they way I did it later. Then I think there is nothing wrong with my conjecture. I will see if I can still edit the original post, otherwise I will post a corrected version of the extremal conjecture. |
| Oct22-10, 09:40 AM | #72 |
In reference to my long post #51, which I can no longer edit, I describe a limited statement about in what sense a spacelike geodesic can be considered minimal. The statement in that post is correct but worded in a coordinate dependent way. I realize a somewhat stronger, more coordinate independent statement is implicit, as follows (you need to read this in conjunction with post #51 for terminology):
Suppose there is a path p between two events with spacelike separation, and interval(p) < interval(nearby geodesic between the same events). Then in every coordinate system in which the geodesic is NNT, p will violate NNT. |
| Oct22-10, 05:09 PM | #73 |
Recognitions:
A more detailed calculation confirms to my satisfaction that the fermi-normal distance will give the same result as the measurement of distance via a Born rigid ruler. (I felt I needed to confirm that the timelike worldlines of the accelerating observers at constant fermi-normal distance were orthogonal to the space-like geodesics along which the distance was measured. This will be true if the metric in these coordinates is diagonal away from the origin, which appears to be the case. Using the same series approach but including higher order terms, I convinced myself that metric was in fact diagonal.) However, I don't believe that passionflower's distance will be equivalent to the distance measured by dropping a Born rigid ruler. |
| Oct22-10, 06:12 PM | #74 |
Just a quick note to acknowledge that Passionflower pointed out a major mistake in my calculations for the motion of a falling body with an initial velocity at infinity in post #69. I have now edited that post and hopefully the equations are now correct. Thanks for checking Passionflower.
It is good to know that someone is checking the posted equations so that they might be a useful and accurate reference to someone in the future .
| Oct22-10, 07:10 PM | #75 |
| Oct22-10, 07:31 PM | #76 |
| Oct22-10, 08:14 PM | #77 |
Recognitions:
Is it true that each hovering observer's local surface of simultaneity in their local inertial rest frame is parallel to a line of constant Schwarzschild time and varying radius? If so, maybe Passionflower's distance would be the proper distance along a single spacelike curve where the tangent at each point along the curve is parallel to the local surface of simultaneity of a freefalling observer at that point?
| Oct22-10, 10:10 PM | #78 |
Hopefully we can work out the kinks because then we have a generic velocity formula for a free falling observer. Then it is simply a matter of finding the Lorentz factor based on the obtained velocity v(r) and divide (because it is length contraction! ) the integrand by the Lorentz factor to get the correct integrand to obtain a proper distance in all free falling radial scenarios (except for acceleration that is, but I think it is better to get the kinks out free falling motion first). By the way, the parametric approach has the advantage that we can extend things to a solution with a rotating black hole by applying some adjustments. As far as I am concerned that would then cover most areas where the notion of distance makes some sense, as the concept of proper (e.g. physical) distance in non-stationary spacetimes do not make much sense to me (except perhaps in things like FLRW models where distances are 'pumped up' in time). To me, but that is likely because I am simple minded, the generic distance discussion is rather academic for arbitrary non-stationary spacetimes as there is really not much to calculate. By the way once this is sorted out it would be really interesting to lay out (in a separate topic) all the Doppler shifts (including a decomposition into kinematical and gravitational components) for all radial motion wrt a stationary local observer, an observer from infinity and of course wrt other free falling observers. As far as I know, no such generic formula is available. |
| Oct22-10, 10:44 PM | #79 |
Starting with the Schwarzschild falling coordinate velocity I gave in #69: [tex] \frac{dr}{dt} = (1-2m/r) \sqrt{\frac{2m}{r}(1-V^2) +V^2} [/tex] and using dr'/dr = 1/sqrt(1-2m/r) and dt/dt' = 1/sqrt(1-2m/r) to relate local measurements of the stationary observer to the observer at infinity such that dr/dt = dr'/dt' (1-2m/r), the local coordinate velocity is: [tex] \frac{dr'}{dt'} = \sqrt{\frac{2m}{r}(1-V^2) +V^2} [/tex] This can be written using A = 1/sqrt(1-v^2) as: [tex] \frac{dr'}{dt'} = \sqrt{\frac{2m/r +V^2A^2}{A^2} } [/tex] [tex]\Rightarrow \frac{dr'}{dt'} = \sqrt{\frac{2m/r + A^2 - A^2 +V^2A^2}{A^2} } [/tex] (because A^2-A^2 =0) [tex]\Rightarrow \frac{dr'}{dt'} = \sqrt{\frac{2m/r + A^2 - A^2(1-V^2)}{A^2} } [/tex] [tex]\Rightarrow \frac{dr'}{dt'} = \sqrt{\frac{2m/r + A^2 - 1 }{A^2} [/tex] [tex]\Rightarrow \frac{dr'}{dt'} = \sqrt{\frac{ A^2 - (1 -2m/r) }{A^2} [/tex] [tex]\Rightarrow \frac{dr'}{dt'} = \sqrt{\frac{ A^2 - g_{\it tt} }{A^2} [/tex] |
| Oct22-10, 11:01 PM | #80 |
Since: [tex] {dt \over d\tau} = {A \over g_{tt} } [/tex] It should be staightforward to convert this coordinate velocity to proper velocity. By the way it would be helpful is someone could attach the relevant page from Hartle, unfortunately I do not have it: http://books.google.com/books?id=azZ...ed=0CC0Q6AEwAA |
| Oct23-10, 12:15 AM | #81 |
[tex] \frac{dr}{dtau} = \sqrt{\frac{2m}{r} + \frac{ V^2}{(1-V^2)}} [/tex] where tau is the proper time of the falling clock. This can be converted to the proper velocity as measured by a local observer at coordinate radius r by using dr'/dr = sqrt(1-2m/r) so that: [tex] \frac{dr'}{dtau} = \frac{1}{\sqrt{1-2m/r}} \sqrt{\frac{2m}{r} + \frac{ V^2}{(1-V^2)}} [/tex] and this can be simplified using A = 1/sqrt(1-V^2) and [itex]g_{tt} = (1-2m/r)[/itex] to: [tex] \frac{dr'}{dtau} = \sqrt{\frac{A^2 - g_{tt}}{g_{tt}}} [/tex] The equation for the local velocity of the falling object given by Hartle is obviously not the proper velocity. [tex] \frac{dr'}{dt'} =\sqrt {{\frac {{A}^{2}-g_{{{\it tt}}}}{{A}^{2}}}} [/tex] the local proper velocity is: [tex]\frac{dr'}{dtau} = \frac{dr'}{dt'}*\frac{dt'}{dt}*\frac{dt}{dtau} = \frac{A}{\sqrt{g_{tt}}} \sqrt {\frac {{A}^{2}-g_{tt}}{A^2}} = \sqrt{\frac{A^2 - g_{tt}}{g_{tt}}} [/tex] |
| Oct23-10, 12:27 AM | #82 |
| Oct23-10, 12:54 PM | #83 |
| Oct23-10, 01:13 PM | #84 |
| Oct23-10, 02:16 PM | #85 |
[tex] v_{(r)} = \sqrt {2m \left( {r}^{-1}-{{\it r_0}}^{-1}\right) } [/tex] which agrees with the mathpages equation I gave in #69 for the proper velocity dr/dtau: [tex] \frac{dr}{dt} = \sqrt{\frac{2m}{r}(1-v_0^2) +2mv_0^2} [/tex] which does not agree with either the mathpages coordinate velocity or proper velocity: ![]() You did not specify if [itex]v_{(r)}[/itex] is intended to be a proper or coordinate velocity or if the observer that makes the measurement is local or at infinity. [EDIT] Actually looking back I am guilty of the same thing in #69 and did not make it clear that all measurements in that post are according to the Schwarzschild observer at infinity. |
| New Reply |
Similar discussions for: "Proper distance" in GR
| Discrete Math "Proper Subsets" | General Math | 23 | ||
| Calculating the "proper mean lifetime" of pions | Advanced Physics Homework | 0 | ||
| "Proper" description of uniform circular motion | Introductory Physics Homework | 3 | ||
| "Proper" accelerations and rigid bodies. | Special & General Relativity | 33 | ||
| The proper article to use in the sentence "A/An NaI detector" | General Discussion | 39 | ||
