| Thread Closed |
Algebra Simplification |
Share Thread |
| Oct16-10, 02:10 AM | #1 |
Problem:
![]() I need to simplify the x equation as far as I can, the y equation is x multiplied by it's conjugate, and the z equation is a failed attempt at further simplification. The last line is me checking which of the 3 (x, y, and z) equations are equal. Basically, I need to take the y equation, keep not change the y at all, and get the other side simplified as much as I can. Thanks! |
| Oct16-10, 02:19 AM | #2 |
Well, first off:
I don't see how "y" is a simplification of "x", or that the corrected "z" would simplify anything. Stick instead with your "x" formula, and you may rewrite this, if not simplifying, as: [tex]x=\frac{\sqrt{\frac{A}{B}}(\sqrt{\sin^{2}\theta-\frac{C\sqrt{B}}{\sqrt{A}}})+\sin\theta}{B}[/tex] This should also tell you where you went wrong in your "z"-expression. |
| Oct16-10, 02:55 AM | #3 |
Thanks, that looks better. But uh...
Plug in the numbers I did in my x equation and you get 0.8164965809... (2/3)^.5 = 0.8164965809... So somehow my x equation simplifies to just (A/B)^.5 |
| Oct16-10, 03:39 AM | #4 |
Well, it doesn't.
For example, with your "x"-expression, setting C=theta=0 makes x=0, rather than equal to the square root of A/B |
| Thread Closed |
Similar discussions for: Algebra Simplification
| ln simplification | Precalculus Mathematics Homework | 7 | ||
| some algebra simplification | Precalculus Mathematics Homework | 4 | ||
| Simplification | Precalculus Mathematics Homework | 3 | ||
| Clifford algebra isomorphic to tensor algebra or exterior algebra? | Linear & Abstract Algebra | 2 | ||
| [pre algebra help] simplification | Precalculus Mathematics Homework | 10 | ||
