What is a process corner and why does it impact semiconductor speed and quality?
The discussion centers on the concept of process corners in semiconductor manufacturing, exploring their definition, implications for speed and quality, and the impact of various factors such as temperature and doping uniformity. Participants delve into the statistical nature of process variations and how these affect chip performance across different manufacturing scenarios.
  • Some participants clarify that a process corner is not a physical corner on the silicon wafer, but rather a model representing extremes in the distribution of process variables affecting chip performance.
  • It is noted that process variables like oxide thickness, effective channel length, and doping concentration exhibit statistical distributions, leading to variations in chip speeds.
  • One participant explains that the term "corner" refers to the corners of a 2D plot of process variables, indicating the extremes of performance metrics.
  • Questions are raised about the effects of temperature on different process corners, particularly whether fast (FF) corners become faster and slow (SS) corners become slower with temperature changes.
  • A drawing is referenced that illustrates NMOS and PMOS speeds across various corners (FF, SS, FS, SF), highlighting that digital logic typically slows down as temperature increases.
  • It is mentioned that not all circuits benefit from faster corners, as some may encounter issues like race conditions, and that analog circuits can face device matching problems at certain corners.
  • Participants discuss the role of process control variances and how different corners may have varying sensitivities, impacting production quality.
Participants express a range of views on the implications of process corners, with some agreeing on the definitions and effects while others raise questions and seek further clarification. The discussion remains unresolved regarding the specific impacts of temperature on different corners and the overall implications for circuit design.
Participants highlight the statistical nature of manufacturing processes and the inherent variability in doping uniformity, which may affect the understanding of process corners. There is also mention of the need to run multiple process and temperature corners to determine performance outcomes.
likephysics
What exactly is a process corner. Is it actually the corner on the silicon wafer?
Why does speed vary in process corners?
Is the doping not uniform?
No, it's not the corner of the wafer. It is a model of the process which attempts to capture the extremes of the distribution of the process. Think of it this way. Say I process a large number of chips across different wafers. There will be a distribution of speeds in those chips, because process variables like oxide thickness, effective channel length, doping concentration, etc. have statistical distributions. There will then be a mean and a standard deviation associated with this speed distribution. The typical process model is supposed to model the mean speed that you would expect to see, and the process corner models are supposed to capture some variation from the mean. Whether it is a 2-sigma variation from the mean, a 3-sigma variation from the mean, or something else depends on how the models are constructed and how your circuit is designed. It is called a "corner" because if I make a plot of several process variables (for example Tox and Leff), then the corner model is usually from the corner of this 2D plot.
To answer your question about doping uniformity, the answer is no, the doping is not perfectly uniform. Any manufacturing variable in the real world is not perfectly controlled and has a statistical distribution associated with it. Even if the process tools are perfect (and they're not), there are statistical variations of things like the number of atoms in each transistor which are inherently random.
Thanks. I have a better understanding now.
But I still did not get the "corner" explanation. Little more detail please.
Are you trying to say the extremes of the plot?
If I have a FF and SS corner. What effect will temperature have on corners.
Will FF become more fast and SS more slow?
Attached is a drawing showing, for example, NMOS and PMOS speed with FF, SS, FS, amd SF corners. Yes, temperature is typically on top of this. Digital logic tends to slow down as it gets hotter, so a (S,S,Hot) corner will typically be slower than a (S,S,Room) corner. However, different circuits respond differently, so you usually have to run all process and temperature corners to determine which is the slowest. Also, people tend to think that the faster corners are always better, but some circuits can be too fast at the fast corners (if your circuit has race conditions for instance). Analog circuits tend to have problems at FS and SF corners where device matching can be compromised.
Thanks. Now I am more informed.
A lot of this also comes down to process control variances. A corner will be your worst case for maintaining production quality but some corners have greater sensitivity than others. Related to Design of Experiment also.
13K
  • · Replies 25 ·
