Dissociation of Acids & Bases into Ions
  • Thread starter Thread starter labinojha
    Dissociation Ions
Acids and bases dissociate into ions in water due to the polar nature of water molecules, which enhances the ionic attraction between the polarized water and the solute. This interaction is stronger than the bonds holding the original molecules together, leading to dissociation. According to Arrhenius' definition, acids and bases produce H+ or OH- ions when dissolved in water, meaning that dissociation is inherent to their classification. This principle extends beyond acids and bases to other ionic compounds like NaCl, which also dissociate into their constituent ions in water. The solvent's polarity plays a crucial role in facilitating this process, as it effectively disrupts the ionic bonds present in the solute.
labinojha
why do acids and bases dissociate into ions while in water?
Chemistry news on Phys.org
It's not just acids and bases...other compounds do it too (ex. NaCl). Look at how they dissociate and which ions are found once they do. Specifically, look at the type of bond between the two ions (hint). What type of solvent is water and how might this play a role?
Generally because water molecules are polar. The ionic attraction between the polarized water molecules and the dissolved atoms are stronger than the bonds in the original molecules.
This is a little bit putting things on the head. By (Arrhenius) definition acids and bases are substances that dissociate in water producing either H+ or OH-. As dissociation is part of the definition, every substance that we classified as acid or base must be dissociating. In effect answer to the question "why those substances dissociate" is "because we have chosen substances that dissociate".
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
