Exist Devices to Assist in Exerting 160+ Lbs of Force?
Devices that can assist in exerting a force of 160 lbs or more include linear actuators, hydraulic ram systems, and screw jacks, which may enable arm movements with minimal effort. The discussion highlights the potential of these technologies for applications requiring significant force without direct physical support. Leverage is also mentioned as a viable method to lift heavy weights, provided the materials used are strong enough. Participants express a need for more detailed information and research on these options. Overall, the conversation centers around exploring mechanical solutions for enhancing arm strength and movement efficiency.
socalfusions
Do any devices exist that can assist your arms in exerting a force of 160 lbs or more in a direction of such where you would have your arms extended and move them up and down, like flapping wings for example, to the effect that you would be using the minimum amount of effort required which would be you just moving your arms and not actually have to support the required weight?
In another post I made about what devices could help in exerting a force of 160 lbs or greater someone mentioned linear actuators, which looked very promising, but I haven't come across solid enough information of whether they could obtain what I am looking for.
Perhaps my more detailed explanation in this thread will be more helpful in determining whether such technology exists, thanks in advance.
Linear actuators, some form of hydraulic ram system or a screw jack.
That's the best I can come up with.
A lever.
Thanks I'll try to do some more research on these suggestions.
russ_watters said:
A lever.
Can you elaborate some more please? :-p
A big lever?
But seriously, with enough leverage, providing the lever material is up to it, you can lift anything.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
