New Reply
Rate of expansion of spacetime
Share Thread Thread Tools
Jan17-11, 11:04 AM   #18
Since spacetime is expanding causing areas of our universe to disappear from view, and regions far away accelerating from us at super luminous speeds can we view these effects as spacetime dividing into dividing into a multiverse of separate spacetimes? Are these separate spacetimes now in effect other dimensions of spacetime separate and beyond our own?
Jan19-11, 12:05 PM   #19
The problem with the "spacetime" theory is that space is NOTHING, which is infinite in distance, and there is no such thing as an entity called "time". "Time" is only our description of what is happening compared with something else that is happening, i.e. the clock's hands indicate one hour has passed for each 1/24 rotation of the Earth. Therefore, since "time" itself as an entity does not exist, it cannot be slowed or speeded up, which throws the theory of time dilation, or "time travel" out the window. The theory of "time" slowing down when nearing the speed of light is bogus. If a nuclear powered satellite's clock seems to change it's "rate of time", it's because the rate of nuclear fusion or fission changes when put into a weaker or stronger gravitational field, not because "time" itself has changed. It's the same as if I mix 5 minute epoxy at 70 degrees, it takes 5 minutes to cure, however, if I mix it at 35 degrees it will take 8 minutes to cure, time has not changed, only the conditions have changed.
So the "space-time continuum" is BS, only something from science fiction. The equation E=MC2 CANNOT be valid, because there is no way to quantify the speed of light to put it into the equation, other than by using numbers created by man's selection of units, i.e. "miles per second", "kilometers per second", and so on, which will give different numbers for the same velocity. The speed of light has NOTHING to do with energy and mass.
Jan19-11, 03:27 PM   #20
Recognitions:
Quote by tajenson View Post
Right. If only Einstein would have thought of that!!
New Reply
Tags
expansion, spacetime, spacetime expansion, speed
Thread Tools
Similar Threads for: Rate of expansion of spacetime
Thread Forum Replies
nitrogen expansion rate? Introductory Physics Homework 3
critical rate of expansion ??? Cosmology 9
Does the expansion of spacetime affect gravitationally bound object? Special & General Relativity 6
Increased Expansion Rate Cosmology 2
Quantum Phase Compactification via Spacetime Expansion General Physics 5
