New Reply
Converting Binary to Mips
Share Thread Thread Tools
Feb1-11, 06:46 PM   #1
Hey everybody! here is my question: Translate the following machine code instructions to MIPS assembly. What is the format of each instruction?
1. 0000 0000 0000 1010 0100 1010 1000 0000
2. 0000 0000 0010 0010 0010 0000 0010 0101
2. Relevant equations
3. The attempt at a solution
Now when trying to figure out the solution of the first, i looked into my book and found an opcode which was the same as the first 6. Which was add.... now i figured out the format:
and got this as a result add $t1, $zero, $t2 is that right? i was unsure because i kinda felt like i left the last part out.... i figured out 0000 00 | 00000| 0 1010| 01001|
but i didn't know if i had to do anything with the ending function --- 101 1000 0000 ?
also the second question i am having trouble figuring it out... i know that the opcode and the function match up to encode a certain type but when im looking for both the opcode and function together in my book/online they only have the opcode? if this is the case then it is another add right?
Your help is appreciated!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb1-11, 07:21 PM   #2
Mentor
I found 22 separate instructions that start with 000000. Go through those and find the one that matches the bits at the end.
Feb1-11, 07:35 PM   #3
okay... so then is that a shift? im looking at this website http://www.student.cs.uwaterloo.ca/~...s/mips/opcodes
of the last of the function am i just matching the last 6? which would be 000000? and the 5 before that would be the shamt (shift) amount?
Feb1-11, 08:26 PM   #4
Mentor
Looks like it to me - SLL (shift left logical) for the first one.
0000 00ss ssst tttt dddd dhhh hh00 0000
hhhhh is the shift amount
ttttt is the register whose value is shifted left
sssss is the register where the shifted result is stored
Feb1-11, 08:50 PM   #5
okay cool, so i have:
OP = sll
$t2 = ttttt
$t1 = dddd
$t2 = h
sll $t1, $zero, $t2
would that be correct?
Feb1-11, 09:07 PM   #6
Also along with the second one,
i figured it would be: or $a0, $at, $v0
Thank you for everything so far!
New Reply
Thread Tools
Similar Threads for: Converting Binary to Mips
Thread Forum Replies
Converting Mips to binary Engineering, Comp Sci, & Technology Homework 13
Help with converting machine language instruction into MIPS assembly instruction Programming & Comp Sci 9
Converting numbers (binary and so on) Engineering, Comp Sci, & Technology Homework 4
Converting Decimal to Binary Electrical Engineering 3
converting decimal to binary Calculus & Beyond Homework 5
