| New Reply |
Energy loss due to friction |
Share Thread | Thread Tools |
| Feb22-11, 04:51 PM | #1 |
A 15.0 kg block is dragged over a rough, horizontal surface by a 74.9 N force acting at 17.6 degrees above the horizontal. The block is displaced 4.91 m, and the coefficient of kinetic friction is 0.266. Find the work done by the 74.9 N force = 351 J Find the work done by the normal force = 0 J What work does the gravitational force do on the block? = 0 J This is the part i can't figure out: How much energy is lost due to friction? And related to that: Find the total change in the block's kinetic energy. 2. Relevant equations Ff = ((mu)k)(mg) E = F*d 3. The attempt at a solution Ef = ((mu)k)(mg) (d) = 0.266*15*9.8*4.91 = 192 J What am I doing wrong? |
| Feb22-11, 07:36 PM | #2 |
The friction force is not (mu_k)mg, it is (mu_k)N, where N is the Normal force, which , in this problem, is not equal to mg. Solve for the normal force first. The use the work energy equation or other method to get the change in KE.
| Feb22-11, 07:41 PM | #3 |
So it'll be : Ff = (0.266)(74.9 sin17.6)
= 6.02 N |
| Feb22-11, 07:47 PM | #4 |
Then I took that and put it in to W = Fd = (6.02)(4.91) = 29.6 J
Still wrong...? |
| Feb22-11, 07:47 PM | #5 |
Mentor
Draw a Free Body Diagram. |
| Feb22-11, 07:49 PM | #6 |
Huh? do i use the mass in there somewhere?
| Feb22-11, 08:45 PM | #7 |
When you draw a free body diagram, you note all forces acting on the block , in both the x and y directions. There are three forces acting in the y direction, one of which is the component of the applied force which you have correctly calculated. What are the other 2 forces acting on the block in the y direction? Then use one of newton's laws to find the unknown force in that direction.
| Feb24-11, 08:46 AM | #8 |
So the frictional force is:
Ff = (mu)k * N = (0.266)* (74.9sin17.6 + (15*9.8)) = 45.1 N But how would I calculate the work done? The block doesn't move in the y-direction, so I would think no work coule be done since W=Fd |
| Feb24-11, 09:00 AM | #9 |
| Feb24-11, 09:40 AM | #10 |
Okay, so my normal force would then be
Fg = N + vertF N= Fg - vertF = (15*9.8) - (74.9sin17.6) = 124 N then my frictional force would be: Ff = (mu)k * N = (0.266) * (124N) = 33.0 N Work done by friction: W = Fd = 33N * 4.91m = 162 J |
| Feb24-11, 11:28 AM | #11 |
| New Reply |
| Tags |
| energy loss, friction, work |
| Thread Tools | |
Similar Threads for: Energy loss due to friction
| Spur Gear, Friction and Energy Loss | Mechanical Engineering | 1 | ||
| Calculation loss of energy due to friction? | Introductory Physics Homework | 2 | ||
| What is meant by friction loss? | General Physics | 3 | ||
| Why is there a pressure loss with friction? | Mechanical Engineering | 8 | ||
| [SOLVED] Conservation of Energy With Loss Due to Friction | Introductory Physics Homework | 6 | ||
