Finite quantum well, factor of 2*pi seems necessary but why?
Villhelm
Solve for the allowed energy values E of a finite square quantum well of depth U0 = 25eV, width a = 0.5nm that contains an electron of mass m (I'm presuming that m = 9.11*10^-31kg, the question doesn't indicate a specific value to use).
I'm defining the interior potential to be 0eV (so that the walls are +25eV).
I'm also defining the well as extending over x = [0,a]
Time-independent schrodinger equation in 1 dimension + some basic DE stuff.
Starting from the TISE, I end up with the following:
2 * sqrt(E*U0 - E^2) / (2E - U0)
= tan(sqrt(2*m*E)*a/hbar)
Upto there I'd (apparently) done things correctly. However, when I estimated the value(s) of E which satisfy the equation numerically I did not get the results that were expected. I did the estimation using openoffice spreadsheet. The tan function is using radians.
My first thought was to see if my value assumed for the electron mass was wrong, so I tried multiples in the range m' = [0.5m,2m] just to see what happened to the results and noticed that the higher the value of m', the closer the values of E that solved the equation came to those I was indicated to have gotten. I tried m'=10m and found that it pushes the values of E too far, so I started iterating through some values until I ended up settling down to m'=6.28m which struck me as being 2*pi*m.
The RHS of the equation now looks like:
RHS = tan(sqrt(2*(2*pi)*m*E)*a/hbar)
and results in a reproduction of the given energy values (there are five, approximately at {1.123, 4.461, 9.905, 17.162, 24.782}eV).
I don't understand why this works, however, especially when the 2*pi is inside the square root.
Using your original equations, I found five solutions close to the ones you listed.
What value are you using for \hbar? The factor of 2π could arise if you're using h instead of \hbar.
Here's a little trick you can use to make evaluating the argument of the tangent a bit easier:
\frac{\sqrt{2mE}}{\hbar}a = \frac{\sqrt{2(mc^2)E}}{\hbar c}a
where c is the speed of light. The mass of the electron is 511000 eV/c2, and the combination \hbar c is equal to 197 eV nm (this is a useful combination to know). If you measure E in eV and a in nm, all the units cancel as you need them to.
I've been using the value \hbar = 6.58 * 10-16 eV.s
Also, for m I was using 9.11 * 10-31kg
I did wonder if maybe I'd messed up with \hbar vs h, but with the 2π inside the square root rather than outside along with \hbar or h made me question that.
I'll use the constant values you've cited and see what I get.
Things seem to work out nicely! Thanks very much.
Incidentally I've just learned a very good lesson from this - I was making assumptions that the values I obtained from the fudge I described above were within reasonable error margins of the values I was given as correct - however I failed to notice that the values were infact _not_ consistent with calculation error because I'd been doing a simple linear interpolation of the value of E which was the root, which was reasonably accurate for the lower E values given the number of digits I was calculating with, but it actually diverged for the higher ones and I hadn't bothered to check more than a glance and just assumed they worked out (why wouldn't they, a factor of 2*pi just _couldn't_ be a coincidence, right?) ...:redface:
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
