Balancing Stacked Coins: Understanding the Physics
  • Thread starter Thread starter Katopanishad
    Physics
When stacking coins, the stability decreases as the height of the stack increases due to a higher center of gravity, which makes it easier for the stack to tip over. The center of mass for the stacked coins shifts, leading to increased potential for instability with lateral displacement. Additionally, the raised edges of coins can create irregularities that further contribute to the stack's instability. The concept of "righting moment," though not detailed in common resources, relates to how the center of gravity affects balance. Understanding these principles is crucial for grasping why stacks of coins can collapse beyond a certain height.
Katopanishad
when we place a coin on top of a table it is balanced because the line connecting the centre of mass and the ground pass though the point which is within the base of the coin.But if start stacking the same type of coins beyond a point it is unstable and this depends on the diameter of the coin.My doubt here is when we stack similar coins the combined centre of mass shd still be on the same initial line.Then why shd the stack of coins collapse beyond a particular no of coins stacked?
Hi Kato...
The higher the center of gravity the less stable the object(s)...there is a greater potential "righting" (really tipping) moment which can topple the pile of coins and it becomes easier to move the higher stack off center...
for example it's tough to topple one coin lying flat, real easy when you have them stacked, say, 50 high...a small horizontal (lateral) displacement does not change the COG of one coin but does when stacked high...different ways of saying the same thing...
Also many coins have a raised edge and this would also tend to make the stack a bit irregular and it might also contribute to the instability.
A search of wiki did not reveal "righting moment" details but the metacentric height of a ship is a roughly analogous concept...
See here for one interesting pictorial description of the center of rotation and center of mass: http://en.wikipedia.org/wiki/Center_of_gravity#Rotation_and_centers_of_mass
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
