Maximum potential (coaxial cable)
The discussion focuses on proving that the maximum potential in a coaxial cable occurs when the inner conductor's radius a equals b/e, where b is the outer conductor's radius and e is the base of the natural logarithm. The user applies Gauss's Law to derive the electric field E between the conductors and calculates the potential difference V as a function of the radii. They express V in terms of the logarithm of the ratio of the outer to inner radius. The user seeks assistance in differentiating V with respect to a to find the maximum potential condition. Clarification on this differentiation process is requested to complete the proof.
weesiang_loke
Given a coaxial cable with outer conductor of radius b, and inner conductor of radius a. Prove that maximum potential is obtained when a = b /e, e is base of natural log.
gauss law, ...
By using Gauss Law,
for a < r < b,
i have E = 2*k*\lambda / r, where \lambda = Q/L
then the potential difference, V= \int E dr
V = 2*k*\lambda ln (b/a),
but i am not sure how to continue by differentiating V wrt a.
Help me pls...
Thank you.
Anyone pls help ...
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
