What Forces Encourage Liquid Down a Straw?
  • Thread starter Thread starter Eliza452
Drinking through a straw involves applying suction that lowers pressure inside the straw, allowing ambient air pressure to push the liquid upward. Once suction stops, gravity pulls the liquid back down the straw, as both ends are at atmospheric pressure. If the straw is in a sealed container, a pressure difference could enhance the effect of gravity. The tilt of the straw affects the friction and rate of liquid movement but does not change the fundamental relationship between pressure and gravity. Understanding these forces can clarify how liquids behave in a straw.
Eliza452
Ok, I did not take thermodynamics and my internet searching made little headway but gave me more questions.
When you drink out of a straw - you apply a suction force overcome the force of gravity. The moment that you stop "sucking" - the liquid goes back down the straw.
What is the force that encouraging the liquid to go down the straw?
My first guess was gravity.
I was also wondering if there was a pressure difference. However, if both ends of the straw are open to the atmosphere - they are both at atmospheric pressure so there is no pressure difference to encourage the liquid to go down the straw? Are pressure and gravity related at all depending if you tilted the straw or something?
To minimize too many forces in my head - I'm focusing on a "slug" of water - that was the term used in some of the internet articles.
My last question is that I ran into the concept of surface tension. It sounds like surface tension/capillary action can lift liquid up but wouldn't their be an equal surface tension on the opposite end of the slug?
Can anyone one help me guide me with what terms/definitions I should be looking at?
More accurately, you lower the pressure inside your (rigid) body, causing ambient air pressure in the (let's say juice container) to push the liquid up the staw.
Yes. Once pressure at both ends of the straw equalizes, gravity pulls the liquid back down, just like anything else.
Not if the juice container is open to air. If it were sealed (such as some tetra packs) then the pressure inside the juice container may be lower, adding to the pull of gravity.
Pressure and gravity won't change, no, but changing the slope of the straw will affect friction and rate of movement.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
