Practical Uses of NOT, OR, and AND Gates
  • Thread starter Thread starter eku_girl83
    Practical
Practical applications of NOT, OR, and AND gates include automated systems like supermarket doors, where NOT gates prevent one door from opening if the other is already open. OR gates can activate lights and music when either door is open, enhancing customer experience. In a basement scenario, OR gates can trigger an alarm if either of two float switches detects water, indicating a problem. AND gates are useful for security, sounding an alarm only when both doors are open, preventing a pet from escaping. These examples illustrate how logic gates can optimize safety and efficiency in various systems.
eku_girl83
Can someone give me an example of where the following types of gates should be of practical use?
NOT
OR
AND
Thanks!
Ok, the automatic doors at a supermarket, the idea is to use two sets of doors to minimize the amount of air that can transfer in/out to minimize heating/cooling costs.
If one door is open then you do NOT want the other door to automatically open.
If one door OR the other door is open turn on the lights promo music in the space between the doors.
If one door AND the other door is open turn on the blower fan to keep the air moving in the desired direction and heat/cool it appropriately.
That help?
Cliff
not: let's say, you have a float in your basement that is nc (normally closed, like a light switch turned on, when not under water). you want to use this float for an alarm. if you wire this float directly to the alarm panel it will be on when the basement is dry! therefore we reverse the incoming signal to the alarm panel through a not gate. consequently; 0=1, and 1=0, so the alarm will only sound when your feet are wet.
or: let's say, you have a large basement with two water infiltration areas, and also two float switches wired no (normally open, like a light switch off when dry). we really don't care which area has water when we are asleep, we just want to know that there is a problem. therefore; we require an alarm whether float # 1 OR float # 2 is under water, and consequently apply these float signals to an OR gate for an alarm.(0 with 0 input=0 output feet dry/no alarm, 0 with 1 input=1 output, feet wet/ alarm, 1 with 0 input= 1 output, feet wet alarm.
and; let's say your dog runs away through two doors every time they are both open at the same time.
we will place a no switch on each door, so that an alarm will sound every time both doors are open, using an AND gate. [0 with 1 input = 0 dog ok & no alarm, 1 with 0 input = 0 dog ok & no alarm, 1 with 1 input = 1 dog may be run over & alarms go off like gang busters (whatever that is) so you to save him/her from peril]
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
