New Reply
Closed form solution
Share Thread
Apr12-11, 01:19 AM   #1
Hi Guys,
What does the term Closed form solution mean?
PhysOrg.com mathematics news on PhysOrg.com
>> Pendulum swings back on 350-year-old mathematical mystery
>> Bayesian statistics theorem holds its own - but use with caution
>> Math technique de-clutters cancer-cell data, revealing tumor evolution, treatment leads
Apr12-11, 02:07 AM   #2
Recognitions:
Homework Helper Homework Help
It means the expression is not infinite in length or can be expressed in a much shorter way.
For example, for each of the following equalities, the right side is a closed form expression while the left isn't.
[tex]1+x+\frac{x^2}{2!}+\frac{x^3}{3!}+...=e^x[/tex]
[tex]1+2+3+...+n=\frac{n(n+1)}{2}[/tex]
[tex]1+\frac{1}{1+\frac{1}{1+\frac{1}{...}}}=\frac{1+\sqrt{5}}{2}[/tex]
Apr12-11, 10:39 PM   #3
I think it also means you can't have an integral or summation symbol of any sort, you have to have simple functions and algebraic operations and numbers. also, what would be a closed form of the roots of x^5 - x + 1 = 0 ? you can't get it by infinite process unless you define a recursive function (such as newton's method) that converges to it, so what is an open form of it?
Jul31-11, 11:27 AM   #4
If the solution is exact, its a closed form solution. For example, a polynomial of fourth order can be solved using quadratic formulae as base(though tedious) or using simple approximate numerical methods. If u solve for exact values(using quadratic formulae), its a closed form solution. So its obvious it can not contain any infinity terms too.
Jul31-11, 12:32 PM   #5
The roots of the quintic equation can be expressed on closed form, thanks to the theta functions which are related to the Jacobi elliptic functions. (Very arduous)
http://mathworld.wolfram.com/QuinticEquation.html
Jul31-11, 12:41 PM   #6
Quote by JJacquelin View Post
But this illustrates one of the difficulties in answering the question. The phrase "closed-form expression" is ambiguous -- it depends on what you define as allowable elementary functions. I mean, if I'm allowed to define new functions, I can express anything in closed form -- I just define a function whose value is the solution to my problem. This sounds like cheating, but that's basically where most of our more recondite special functions come from: elliptic functions, Bessel function, Hypergeometric functions, etc. There was no closed-form expression to the problem so some old 19th century German said, "I hereby define this function to be the solution." And presto! the problem had a closed-form solution.
Aug1-11, 01:31 AM   #7
I agree, but even if this way to see things is correct it is still incomplete. Of course, it should be too easy to define a new special function as the solution of a problem and then, to say : The problem as a solution which is expressed thanks to the new special function !
Special functions are more than that. For exemple, consider the Riemann zeta function.
If you say : I define a closed-form expression f(x) for the infinite series of general term 1/n^x (for n=1 to infinity), the function f(x) is defined only for x>1 since the series doesn't converges for x<1. However zeta(x) is defied for any real x (except x=1) and even for complex x. The special function zeta covers much more background : integral definition of the function, analytic continuation and much more.
In fact, when we use a closed-form expression to express the solution of a problem, we refer to a background of knowledge and we give a relationship to standard functions, i.e. functions which have been widely studied.
If the solution of a problem is only used to define à new special function, a relationship is not established to any previous background. So, this supposedly "closed-form" is useless.
A funny example is given as a preamble in the paper "Sophomores Dream Function" (pp.2-3). By the link :
http://www.scribd.com/JJacquelin/documents
This is also a main theme in the paper "Safari au pays des fonctions speciales" ( not translated yet), same link.
Aug1-11, 06:57 AM   #8
Yes -- I was exaggerating a bit for effect. Actually, elliptic functions are an interesting case, because, although it is true that Jacobi developed them essentially as I described, as an easy-out function to solve a particular class of problems, they're more broadly applicable. I doubt he was thinking of solving quintics.
New Reply
Similar Threads for: Closed form solution
Thread Forum Replies
*simple* example of mechanics problem with no closed-form solution? Classical Physics 10
Free damped pendulum solution : closed form Differential Equations 0
Closed form solution Calculus & Beyond Homework 3
3D closed-form triangulation solution Engineering Systems & Design 1
closed form solution for series Calculus & Beyond Homework 2
