New Reply
cross section calculation
Share Thread Thread Tools
Apr21-11, 11:00 AM   #1
Hi everybody,
I have a experimental question. In cross-section calculation of production of particles (say D), one counts the number of produced D. To selection the D one has to apply some kinematic cuts. If cuts are tight, number of D will be less and if cuts are loose, number of D will be large. So, cuts is going to effect the calculated cross-section. How these effect is taken into account?
Thanks.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Apr21-11, 02:32 PM   #2
Generally, what is actually calculated is a differential cross-section. This is then integrated numerically in the allowed phase space region- the cuts come in as boundaries of allowed phase space.
Apr22-11, 01:21 PM   #3
Ok, thanks for reply.
My question is when you are analyzing the real data. You see a peak of a particle D, you select that particle by taking cuts around its peak, and count the number of events giving that particle. To calculate the cross-section, you divide the number of D particle by flux. Now, the number of D particle depend on the cut around the peak. How do take care of effect due to different cuts? Does not the cross-section depends on the cut you are taking to select D particle?
New Reply
Thread Tools
Similar Threads for: cross section calculation
Thread Forum Replies
Getting Extinction cross section from Radar cross section using HFSS Electrical Engineering 0
finding the shear centre of a non-homogeneous cross section cross Engineering, Comp Sci, & Technology Homework 2
Volume by cross-section: ellipse and equilateral triangle cross sections?? Calculus & Beyond Homework 0
Compton Scattering cross section calculation Advanced Physics Homework 1
Cross Section calculation Advanced Physics Homework 2
