Best computational tool that could be used for calculation of thermal stresses
For calculating temperature distribution and thermal stresses in structures, standard Finite Element Analysis (FEA) packages like ANSYS and ABAQUS are generally suitable. ANSYS Workbench and DesignModeler are recommended over Mechanical APDL for easier handling, especially for marine structures. Users should avoid IGES for geometry import/export, opting for formats like Parasolid or STEP instead for better results. The capabilities of FEA packages can vary significantly, especially for complex thermal analysis involving convection, coupled fluid-solid problems, or phase changes. Selecting the right tool depends on the specific requirements of the thermal analysis needed.
chetanladha
Hi everyone.
I am working to find out temperature distribution and thermal stresses in a structure. Can anyone please advice on which could be the best computational tool (ANSYS or ABAQUS or any other) for such kind of calculations.
Thanks in advance.
Define "best computational tool." Pretty much any standard Finite Element Analysis package is capable of the analysis you're looking for.
Thank you for your response.
I have been trying to use ANSYS Mechanical APDL, but i am finding it difficult to make a marine structure. I even tried to use a drafting package and export it to ANSYS (IGES format), but it didn't work out very well..
Could you suggest any other package?
For a start, I would recommend using ANSYS Workbench and DesignModeler rather than APDL unless yuou're very familiar with the program's inner workings.
Second, I wouldn't use IGES as your geometry import/export format. I've found that using something like Parasolid or Step will yield much better results.
Pretty miuch any standard FE package will do a thermal stress calculation given a temperature distribution (i.e. the temperature at each mesh point of the FE model).
However the thermal analysis capabilities of different FE packages vary quite a lot, if you want to anything "complicated" like
- Convection boundary conditions with user-defined laws for heat transfer coefficients (typically the HTC woudl be a function of a few non-dimensional fluid dynamics parameters),
- Coupled fluid-solid thermal problems where heat is carried in the moving fluid,
- Phase changes like freezing or melting,
- The need for different meshes for the thermal and structural models,
- etc.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
