Limit switch explained in everyday language
The discussion centers around the functioning of limit switches, aiming to explain the concept in everyday language. Participants seek to clarify the technical aspects and applications of limit switches in various mechanisms.
  • One participant requests a simpler explanation of limit switches, indicating that existing sources are too technical.
  • Another participant suggests sharing the sources for better assistance.
  • A link to a specific article about limit switches is provided, but one participant finds it difficult to fully understand the content.
  • It is noted that a limit switch differs from other switches in that it is connected to a control function that modifies a process when activated.
  • Participants mention various types of limit switches, including mechanical switches and optical switches, explaining their operation in relation to moving parts.
  • One participant describes a mechanical limit switch that operates by an arm being compressed, which then turns off a motor, and contrasts this with an optical limit switch that uses light interruption to function.
  • It is stated that limit switches are commonly found in electro-mechanical systems involving significant movement and are often monitored by controlling software.
Participants generally agree on the basic function and types of limit switches, but there is no consensus on the clarity of the explanations provided, as some find the technical details challenging to understand.
Some participants express difficulty in comprehending the technical sources, indicating a potential gap in the explanation of concepts and terminology related to limit switches.
Stanley_Smith
Can someone explain to me how limit switch works in everday language, I got some sources that are too technical.
Thank you,
Stanley_Smith said:
...I got some sources that are too technical.
Thank you,
Share the sources and maybe we can help.
Regards
Don
http://www.ab.com/sensors/products/limit_switches/
I find it's not very easy to comprehend 100% the whole article
The real difference between a "limit" switch and any other switch is that it is connected to a control function.
In other words activation starts, stops or otherwise modifies some process.
Your link is to a particular device that can be used for this function.
There are other types using light, magnetism, pressure ect.
You could take the light switch off your wall and use it as a limit switch.
It is simply a switch which is activated by something "hitting" it. There are many different types of limit switches.
If you have a mechanism driven by a motor, it is very helpful to know when you have reached the end of your motion range. You can to this with a mechanical switch which is simply a micro switch with a arm attached. When your moving part compresses the arm the switch flips and turns off your motor (That is not the actual mechanism, but essentially what happens).
There are also optical limit switches, for these you attach a "flag" to your moving part, the flag (a tab of metal) passes through the optical switch it blocks passage of light (the source is a LED) and trips the switch.
Limit switches are on virtually all electro-mechanical mechanisms which involve movement of significantly massive parts. In modern equipment they are usually monitored by the software which is controlling the motion.
  • · Replies 33 ·
  • · Replies 19 ·
  • · Replies 42 ·
  • · Replies 49 ·
