New Reply
Transformer vector group Dyn11 and Dyn1
Share Thread Thread Tools
May11-11, 01:07 PM   #1
please i need your help to answer the following question
what the difference between transformer Dyn11 and Dyn1
i know the difference is in leading and lagging of line to line voltages of primary and secondary
but the question is , when i should use Dyn11 or Dyn1 as a must in the network
does it depends on the type of load ?
all what i know that in parallel operation the 2 transformers must be exactly the same ,
but what according to what in the first place we choose Dyn1 or Dyn11
anybody have an idea ???
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
May11-11, 06:14 PM   #2
Recognitions:
Gold Membership Gold Member
According to most standards transformer coils are classed as either Delta (D), Wye (Y) or Zigzag (Z).
Dy11 signifies a Delta Primary (primary has an upper case letter), Wye secondary (secondary has a lower case letter) and the orientation of the 3 phase diagram, relative to the A phase on a clock face pointing to 11 o'clock.
So draw 3 vectors 120 degrees apart to represent the 3 phases, but start with your reference phase (A phase) at 11 o'clock.
Dy1 would hence be a Delta primary, Wye secondary and a vector diagram with the reference vector pointing at 1 o'clock.
I believe most 3 phase textbooks have the vector diagram with the reference vector at 0 degrees on the x-axis, which would equate to 3 o'clock, then with B at 11 o'clock and C at 7 o'clock.
Any combination of a Delta coil and a Wye coil (Dy or Yd) will cause a phase shift by +/- 30 degrees. Therefore we use another Delta coil and Wye coil combo to shift it back to whatever is desired.
And yes, if you want to parallel transformers they have to be of the same vector group or you will have circulating currents and associated problems.
New Reply
Thread Tools
Similar Threads for: Transformer vector group Dyn11 and Dyn1
Thread Forum Replies
question on group actions on vector spaces Linear & Abstract Algebra 5
vector diagram for no load single phase ideal transformer Engineering, Comp Sci, & Technology Homework 1
Isometry sub-group of the gauge group & the center of structural group Differential Geometry 0
Lorentz group, Poincaré group and conformal group Special & General Relativity 12
Left invariant vector fields of a lie group Calculus & Beyond Homework 2
