| New Reply |
Strengthening Aluminum (casting mix) |
Share Thread | Thread Tools |
| May24-11, 07:33 PM | #1 |
I want to cast a part out of Aluminum (from scraps). Is there anything I can throw into the melt mix to make it come out stronger (not as gummy and soft) ??
Some sort of ceramic I'm thinking? Very fine sand-like stuff (e.g. CaCO3)? Any suggestions for heat treatment too? The part will be a shell-type housing, needs to be strong and stiff. |
| May24-11, 09:36 PM | #2 |
Admin
See - Aluminum Alloys – Effects of Alloying Elements
http://www.keytometals.com/page.aspx...site=ktn&NM=55 See also - http://www.keytometals.com/page.aspx...icles&LN=EN#p2 Look under +The Basics of Nonferrous Metallurgy There's a number of articles on Al and alloys. |
| May24-11, 10:18 PM | #3 |
Good stuff.
So if I add some Iron to the mix, how should I cool in order to keep a homogeneous (as close as I can) mixture after hardening. I don't want to form a distinct two phase composite, as I suspect it will lead to crack formation. What is it talking about here: "The solubility of iron in the solid state is very low (~0.04%) and therefore, most of the iron present in aluminum over this amount appears as an intermetallic second phase in combination with aluminum and often other elements." |
| May25-11, 01:10 PM | #4 |
What kind of aluminum scraps are you using? If it's pure aluminum, you can add the components necessary to form a higher-strength alloy like 6061 or 7075. Then after casting, you can apply a heat treat like -T6 or -T651 to get the most stength you can out of it.
If its a mix of different aluminum alloys you don't know, well you'll basically be stuck with what you get... |
| May25-11, 07:01 PM | #5 |
It is most likely going to be 6061 heat treated aluminum scraps.
And how should the heat treatment go in order to get highest strength? I remember doing this in a lab at some point but I forgot it completely. |
| Jun14-11, 08:14 AM | #6 |
Solution heat treat at 990 F for adequate time to allow for thorough heating and then water quench. Precipitation hardening is done at 320 F for 18 hours and air cool, followed by 350 F for 8 hours and air cooling.
Its easy to find by googling 6061 heat treatment. |
| New Reply |
| Thread Tools | |
Similar Threads for: Strengthening Aluminum (casting mix)
| Strengthening Aluminum | Materials & Chemical Engineering | 18 | ||
| Strengthening of non-heat treatable alloys | Materials & Chemical Engineering | 1 | ||
| Strengthening In Aluminum Alloys | Materials & Chemical Engineering | 5 | ||
| Knee strengthening exercise | Biology | 9 | ||
