Prove equations for asymptotes of standard hyperbola
  • Thread starter Thread starter JsStewartFan
    Hyperbola Standard
The discussion focuses on proving the equations for the asymptotes of the standard hyperbola x^2/a^2 - y^2/b^2 = 1, specifically y = -(b/a)x and y = (b/a)x. A participant attempts to use the limit definition of asymptotes but encounters an error in their calculations. They express a desire to derive equations rather than memorize them, indicating a deeper engagement with the material. Another participant shares their successful proof using different methods, including separating the proof into quadrants due to the hyperbola's nature. The conversation highlights the challenges and methods involved in understanding hyperbolas and their asymptotic behavior.
JsStewartFan
Prove the equation(s) for the asymptotes of a standard hyperbola. That is, prove that the asymptotes for the hyperbola x^2/a^2 - y^2/b^2 = 1 are
y = -(b/a)x and
y = (b/a)x
where foci are at (c,0) and (-c,0); vertices are at (a,0) and (-a,0); difference in distances between the two foci and any point on the hyperbola is a constant 2a or -2a; and
c^2 = a^2 + b^2.
If lim(x→∞) [f(x)- (mx+b) ]= 0, then y= mx + b is the equation of an asymptote of f(x).
Using the definition of the asymptote in terms of the limit difference in (2) above, I focused on the first quadrant of the hyperbola and came up with this sequence of equations, but since (-b) does not equal zero, I have an error somewhere:
lim(x→∞)[b/a (x-a)+ bx/a]
= lim(x→∞) [(bx-ba)/a + bx/a]
=lim(x→∞) [(bx-ba+bx)/a]
=lim(x→∞) [(-ba)/a]
= (-b)lim(x→∞)1
= (-b)• 1
= -b ≠ 0
By the way, this is in James Stewart's Calculus - Early Transcendentals, 5th edition, section 4.5, problem 67, page 324. There's no answer in the back of the book. I am reviewing hyperbolas for a high school teacher certification test and got off on this "tangent" because I like to derive or prove equations instead of just memorizing them (when I have time).
Thanks for your help.
Do you have to use the definition in terms of the limit difference?
By the limit difference, I just meant the definition for the asymptotes that says if the limit as x approaches infinity of (f(x) - (mx + b)) equals zero, then that y=mx+b is an asymptote of the function f(x), which is the hyperbola in question. It's listed under related equations.
I wasn't sure what you meant by liking my whiteboard, but I used MS Word 2007 with Equation Tools to write out the limit expression. Then I copied and pasted. I've never used Latex Reference before, so I used what I knew.
Also, could you help me with navigation? I can't figure out a quick way to get to the homework and course work help section.
Thanks!
Terry
Oh, I read your question wrong. I think since Mr. Stewart only explained slant asymptotes in terms of the limit definition, that he's expecting me to use it here. This is a problem right after that section. I know I can use setting the hyperbola to zero instead of 1 (saw that in another post here), but I should be able to use limits to prove it, too.
Thanks,
Terry
I finally found the homework and course work section under Science, so I'm OK there.
Thanks,
Terry
QuarkCharmer:
I think I've proved this two ways - one I found in Sullivan's Algebra & Trigonometry book (proved in the text), ed. 7, page 793. The other one I proved using the difference of limits as I wanted to, but I had to separate the proof into the four quadrants, since the hyperbola is not a function unless I do that. It turned out OK, I think.
I'd like to send it to you, but I took about 30 minutes after I copied and pasted my new Word document, trying to fix all the spaciing and so forth - then I was logged out automatically and lost it all. Let me know if there's some way I can get the Word document to you.
I'd appreciate you looking at it for me, and maybe you can post it to this question if correct.
Thanks,
Terry
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
