xNick94 said:
Sorry for the late reply, had to work and family friends were visiting.
Would you then have to multiply it since 4/9 is under 1.
3.1x10^-8 x 4/9 = 1.3 x 10^-8
Would the force be just 1.3x10^-8 or would i have to subtract that from 3.1x10^-8?
The multiplication is correct. Though you have merely "truncated" the answer rather than round it off - it should be 1.4 x 10^-8 when rounded to 2 figures.
Fortunately if you had subtracted 4/9 form 3.1 x 10^8 you would get approximately -4/9 and thus recognise it as wrong.
4/9 was a factor, and you either multiply or divide by factors.
Fractions are always a problem, because often work backwards: multiplying by them you get smaller, divide you get bigger.
The way I would have done it - which ultimately is numerically the same thing - is.
Since separation is changing from 3 to 4.5 - not an integer factor change - I would work on an interim separation of 1.5 m
This is half the first separation - meaning 4 x the force or 12.4 x 10^-8
I then change to 4.5.
This is 3 times the interim separation so it if F / 9 or 1.377778 x 10^-8
Rounding to 2 significant figure this is 1.4 x 10^-8
********** Be careful to always do calculations to as many figures as your calculator can handle - then at the end
ROUND OFF, don't just chop off the last figures.**************
