Why Does Strumming Force Not Alter the Pitch of a Guitar String?
Guitar strings behave like springs, where the tension affects the frequency according to the formula F = k.x. When a guitar string is plucked, the force applied alters the amplitude of the sound but not the pitch, as the tension remains relatively constant during normal playing. Significant changes in frequency occur only with large displacements, which are atypical in standard playing. The initial tension set during tuning is crucial for determining the tone of the string. While a slight frequency shift can be perceived with hard plucking, it is generally minimal compared to the change in amplitude.
jaumzaum
Guitar strings behave like a spring when tuned:
F = k.x is the tension in the string, where k is the contant of the string and x the displacement (when tuned). So by the equation :
v = \sqrt{ F/u}
where u is the linear density of the string.v = \lambda.f -> f = \sqrt{ F/u}/\lambda
The first string of a guitar is E and has a frequency f1, when tuned, that is proportional to the square root of the string tension.
But when we play the first string weakly, we seem to hear the same E note (sure, more weak) and when we play strongly, we seem to hear this same E stronger. So the force we apply in the string does not seem to change the frequency, only the amplitude. But in a spring, when we make a vertical displacement
[PLAIN]http://img716.imageshack.us/img716/6427/sgfhdf.jpg
The tension do change
So why don't we have a change in the frequency?
Even for quite large displacements, the string tension doesn't change enough to affect the wave speed significantly. Indeed, constant tension is one of the assumptions we make when deriving the wave speed formula you've quoted. The derivation involves the transverse acceleration of the string due to transverse components of the tension which arise when the string is displaced.
For very large displacements, you're absolutely right: the note will change. It will also be far from pure!
That's the right answer, but just to make it perfectly clear, there's a big difference between a spring that is not stretched, for which plucking causes all the stretching, versus a spring that is already stretched when you pluck it. The guitar string is the latter case, so that plucking really doesn't increase the already significant tension. Indeed, you know that when you "tune" the guitar, you do so by altering the initial tension, so that's what is key in producing the tone.
Actually you do hear a slight frequency shift when you pluck hard on a stringed instrument.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
