Spin 1/2 Basis Change Homework Solution
beebopbellopu
This is from my first-quarter graduate QM course. Part 4 of this problem asks me to compute the unitary operator U which transforms Sn into Sz, where Sn is the spin operator for spin 1/2 quantized along some arbitrary axis n = icos\phisinθ + jsin\phisinθ + zcosθ.
From part 1, I solved Sn = \begin{pmatrix} cosθ&sinθe-i\phi\\ sinθei\phi&-cosθ \end{pmatrix}
|n;+> = cos(θ/2)|+> + sin(θ/2)ei\phi|->
|n;-> = sin(θ/2)|+> - cos(θ/2)ei\phi|->
where |+> and |-> are the spin up and down states along the z-axis
Also: U(adjoint)SnU = Sz
U = Ʃ|n;±><±| = |n;+><+| + |n;-><-| = [cos(θ/2)|+> + sin(θ/2)ei\phi|->]<+| + [sin(θ/2)|+> - cos(θ/2)ei\phi|->]<-|
I then calculated out <+|U|+>, <-|U|+>, <+|U|->, and <-|U|-> to get the 4 elements of the unitary operator matrix, and end up with:
U = \begin{pmatrix}cos(θ/2)&sin(θ/2)ei\phi\\sin(θ/2)&-cos(θ/2)ei\phi\end{pmatrix}
However I used that to transform Sn and could not recover Sz. U(adjoint) is just the transpose complex conjugate so then I should be using:
U(adjoint) = \begin{pmatrix}cos(θ/2)&sin(θ/2)\\sin(θ/2)e-i\phi&-cos(θ/2)e-i\phi\end{pmatrix}
I'm not quite sure where to go from here.
Edit: I also can't figure out how to post matrices, if someone can help with that also. Thanks!
Edit 2: Thanks vela for the fix.
Fixed your LaTeX.
From part 1, I solved Sn = \begin{pmatrix} \cos\theta &amp; e^{-i\phi}\sin\theta \\ e^{i\phi} \sin \theta &amp; -\cosθ \end{pmatrix}
where |+> and |-> are the spin up and down states along the z-axis.
U = \begin{pmatrix} \cos(\theta/2) &amp; e^{i\phi}\sin(\theta/2) \\ \sin(\theta/2) &amp; -e^{i\phi}cos(θ/2)\end{pmatrix}
U^\dagger = \begin{pmatrix} \cos(\theta/2) &amp; \sin(\theta/2) \\ e^{-i\phi}\sin(\theta/2) &amp; -e^{-i\phi}cos(\theta/2)\end{pmatrix}
Okay so I did out the matrix math a little further, found some more double angle identities and so forth, and if I set \phi to 0 after multiplying through it comes out to σ3 which is what I want for Sz.
I think that this is because the unitary operator has to keep the inner product and its therefore an orthogonal transformation, meaning U must be orthogonal. If that's the case then it has to have real elements and the only way for that is if phi = 0, which makes sense in that the the azimuthal angle needs to be 0 in order to be orthogonal to the z-axis.
Is that correct?
Your matrix for Sn is missing an overall factor of 1/2.
If you multiply the second eigenvector by e-iΦ, you'll have
\begin{align*}
\vert + \rangle_n &= \begin{pmatrix} \cos(\theta/2) \\ e^{i\phi}\sin(\theta/2) \end{pmatrix} \\
\vert - \rangle_n &= \begin{pmatrix} e^{-i\phi}\sin(\theta/2) \\ -\cos(\theta/2)\end{pmatrix}
\end{align*}(It's not really necessary to do this. I'm just doing it for aesthetic reasons.)
If you recall your basic linear algebra, you know that the matrix U that diagonalizes Sn has the eigenvectors of Sn as its columns, so you haveU=\begin{pmatrix} <br /> \cos(\theta/2) &amp; e^{-i\phi}\sin(\theta/2) \\ <br /> e^{i\phi}\sin(\theta/2) &amp; -\cos(\theta/2)<br /> \end{pmatrix}
You can verify that this matrix is in fact unitary for any value of the angles and that it will diagonalize Sn. Requiring Φ=0 isn't acceptable since n can point in any direction.
For some reason, you ended up with the transpose of this matrix.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
