Reusing Old PC Power Supply: Making Voltage Source & Safety Tips
Reusing an old PC power supply can be a practical way to create a simple voltage source. To safely access the voltage from the cables, users should identify the color-coded wires that correspond to specific voltages, such as 12V DC. Caution is advised, as short-circuiting the output may trigger a crowbar breaker, which requires unplugging and re-plugging to reset. It's important to understand the power supply's specifications, including its wattage and amperage limits. Proper handling and knowledge of the power supply's wiring can ensure a safe and effective reuse.
Bassalisk
Hello,
I just stumbled upon an old PC power supply. I thought it would be a good idea to reuse it. I am thinking making out of it a simple voltage source, as it is already voltage source.
Can somebody explain me how can I safely get that voltage from those hanging cables that go into HDDs, CD roms etc. And would anything special happen if I accidentally short circuit that output(12 V DC or so).
Voltage source is pretty old, it has 175 W and a bunch of other technical stuff written on it. Peak amperage, voltage etc. If you are interested I can write that down too.
You should just Google "PSU" and find out which colors (the leads are color-coded) correspond to which voltages. That will let you know which wires to isolate for your use(s). Have fun.
Thank you (:
I have seen some supplies that have a crow bar type of breaker in them that does not reset until you unplug and plug back in.
so if you short something out and it doesn't work, try unplugging it for a few seconds and plugging back in.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
