Can some one check my work? Related Rates
by nyr
Tags: check, rates, work
nyr
nyr is offline
#1
Nov16-11, 03:43 PM
P: 17
The problem is:
For the baseball diamond in exercise 33, suppose the player is running from first to second at a speed of 28 feet per second. Find the rate at which the distance from home plate is changing when the player is 30 feet from second base.
(the picture basically shows a square with 90 ft sides)
__________________________________________________
My solution
Given: dy/dt = 28 ft/sec
Find: ds/dt when x=30
902y2=s2
0 +2y(dy/dt)=2s(ds/dt)
2(60)(28)=2(30√13)(ds/dt)
56/(√13) ft/sec=ds/dt
I'm not really sure if its the correct answer because I always seem to mix up negative signs and I wasnt sure if this required one.
If you really need to see the picture its found here:
http://books.google.com/books?id=E5V...20base&f=false
Page 151 #34
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
Mark44
Mark44 is online now
#2
Nov16-11, 08:32 PM
Mentor
P: 20,999
Quote Quote by nyr View Post
The problem is:
My solution
902y2=s2
It looks like you left out the + sign on the left side. The equation should be
902 + y2=s2
Looks fine to me.
Page 151 #34
Register to reply
Related Discussions
Related Rates, why doesn't my solution work? Calculus & Beyond Homework 5
intrest rates/investment problem (pert), I just need someone to check my work:) Precalculus Mathematics Homework 2
Related rates Engineering, Comp Sci, & Technology Homework 0
Related Rates Problem (Check work) Calculus & Beyond Homework 2
Related Rates Introductory Physics Homework 8
