Clamping circuit for electromagnetic wave
A clamping circuit for electromagnetic waves is being sought to limit a signal with amplitudes of 5 and -10 to 1 and 0, respectively. For microwave frequencies, AC coupling with a diode to ground can clamp negative excursions but may not be suitable for the desired positive voltage, which is variable. The discussion suggests using a resistive divider or transformer to adjust the positive value. Concerns are raised about the necessity of a DC component in a microwave signal, with a preference for avoiding diodes or transistors. The goal is to achieve a unit step function response in the circuit design.
r_rajesh77
Hi,
I am looking for clamping circuit for electromagnetic waves. I have a wave which has amplitude of 5 and -10. is it possible to clamp it to 1 and 0 respectively. I want a positive side clamp to be +1 units and negative side clamp to be 0 units. is it possible to realize using any electromagnetic wave devices like waveguide or so.
Thanks,
Rajesh
What frequency do you want this to operate on?
For manageable frequencies, AC coupling, followed by a diode connected to Earth (Anode to earth) would limit the negative excursion to -0.7V (less with an appropriate diode) and the positive excursion to 15V (in your example?). You can then use an appropriate resistive divider (or transformer) to reduce the positive value to what you want.
Is this too simplistic a solution? Only, at higher frequencies, signals tend to be AC coupled and do not need to be clamped.
Hi sophiecentaur, thanks for the reply. I am looking for using microwave. i have an additional requirement. the positive voltage is not fixed at 15v. it can be a variable. in that case what circuit can be used.
Thanks,
Rajesh
I have to ask why you need your microwave signal to have a DC component?
I was trying to create a comparator circuit and I end up in this scenario. I prefer not to use diodes or transistor, but i can definitely go with resistor divider. my requirement is the signal should clamp to some thing like unit step function. here i'm. looking for solutions.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
