New Reply
Proof about symmetry (simple)
Share Thread Thread Tools
Dec23-11, 01:58 AM   #1
Show that the curve is symmetrical about the x axis (without drawing the graph)
eq of the curve is : x^2 + 4y^2 = 1
also show that the curve is symmetric about the y axis
2. Relevant equations
3. The attempt at a solution
To prove that the curve was symmetric abou the x axis, i made x the subject of the equation of the curve:
x=(1-4y^2)^0.5 (can be positive or negative)
Then i used simple intuition:
let a particular value of y be "k" and the corresponding value of x be "c".
by simple calculation, we can conclude that for y=-k , x will still be equal to "c"
Can anyone guide me if this proof is enough or it lacks something, for the latter case, please provide an alternative but suitable proof.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Dec23-11, 10:28 AM   #2
Mentor
Quote by hms.tech View Post
Generally, simply use the original equation. If you replace y with -y, and the resulting equation is equivalent to the original equation, then the graph is symmetric w.r.t. the x-axis.
For symmetry w,r,t, the y-axis, replace x with -x, in the original, and check to see that the result is equivalent to the original.
Dec23-11, 10:34 AM   #3
Recognitions:
Homework Helper Homework Help
It is enough proof to show that f(x)=f(-x) for symmetry about the y-axis, and f(y)=f(-y) for symmetry about the x-axis. Can you see why?
Basically, this just means you just need to show that the function doesn't change when you swap x for -x and y for -y.
edit: If I bothered to refresh the page to see if a reply was already made, we wouldn't be here right now...
Dec23-11, 02:06 PM   #4
alright, from your replies i think the method i used is correct.
So thnx guys !
cheers
Dec24-11, 06:50 AM   #5
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Yes, correct, but do you understand that everyone was telling you that you don't have to solve for one variable?
New Reply
Thread Tools
Similar Threads for: Proof about symmetry (simple)
Thread Forum Replies
continuum mechanics symmetry proof Introductory Physics Homework 0
Special relativity: proof of symmetry concept Introductory Physics Homework 2
Proof of transformational symmetry Calculus & Beyond Homework 1
SU(3) symmetry and simple zeros of w. f. Quantum Physics 2
Symmetry of a circle proof Introductory Physics Homework 8
