What Are the Probable Values of Energy and Momentum for a Free Particle at t=0?
nikolafmf
At time t=0 free particle is found in state psi=const*sin(3x)*exp[i(5y+z)]. What values for energy and for momentum we can get if we measure them at t=0 and with what probability?
Well, we know that eigenvalues of energy and momentum operator for free particle are (hbar*k)^2/(2m) and hbar*k respectively.
So, does measured momentum equal hbar*(0, 5, 1) and energy 13(hbar)^2/m? Is probability 100%? Book hints that we can get different values for momentum, not just one I stated before. How is it possible?
You've got the y and z momentum correct. But You've not got the correct x momentum. In the wavefunction, the bit that depends on x is: sin(3x) So you've got to think of how to express this in terms of eigenstates.
With the use of Fourier transform? But if my limits of integration are infinity, I get diverging integrals. What limits should I use?
you don't need to do anything complicated. I'm sure you must have learned about how to write a sine function as a sum of two complex exponentials... (that's the hint)
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
