| New Reply |
Proof of relativistic energy/mass to grow to infinity for v approaching c? |
Share Thread | Thread Tools |
| Jan5-12, 11:42 AM | #1 |
By SR, relativistic energy and mass are proportional to the Lorentz factor γ, therefore, grow to infinity for v[itex]\rightarrow[/itex]c. This relationship for the relativistic mass has been confirmed by the Kaufmann experiment and its successors, via measuring the deflection of high velocity electrons by an electric and/or magnetic field.
My question is: is this really unambiguous proof of energy/mass increase? Or, could as well the effective electric (and/or magnetic) deflection force on the electron go to zero for v[itex]\rightarrow[/itex]c, such that the inertial mass (and energy) only appears to increase? |
| Jan5-12, 11:48 AM | #2 |
Mentor
Hi Vincentius, welcome to PF!
Generally, the concept of relativistic mass has been discarded by modern physicists. However, from particle accelerator experiments it is abundantly clear that the total energy increases to infinity for v->c. Or, if not to infinity, then at least for as high energy as we have been able to probe thus far. If it were just a decrease in the Lorentz force then there wouldn't be enough energy to make the reaction products that we observe. |
| Jan5-12, 12:57 PM | #3 |
Thanks DaleSpam. Yes, I know the particle accelerators run on high energy to make the reaction products. However, if an electron is being accelerated over a potential of 1 V, then the electron is considered to have acquired 1eV of energy in kinetic energy. But does this still hold at relativistic velocities? How can we be sure the effective force of the accelerating field isn't falling off with the velocity of the electron (like the deflection force in my original question)? On the basis of which experimental result can this possibility be ruled out?
| Jan5-12, 01:59 PM | #4 |
Mentor
| Jan5-12, 02:14 PM | #5 |
| Jan5-12, 02:30 PM | #6 |
Mentor
| Jan5-12, 03:36 PM | #7 |
Mentor
Or you send the particles through a magnetic field and measure the curvature of their path, which gives you the momentum. From the momentum, you get the energy from [tex]E^2 = (pc)^2 + (m_0 c^2)^2[/tex] and then the kinetic energy from [itex]K = E - m_0 c^2[/itex]. |
| Jan5-12, 04:55 PM | #8 |
On the second method: I understand the principle, but this deflection method raises the exact same question of my original post. |
| Jan5-12, 05:46 PM | #9 |
(1) http://en.wikiversity.org/wiki/Special_relativity (2) http://en.wikipedia.org/wiki/Mass-to-charge_ratio The predictions of you theory should fit the experimental results! |
| Jan5-12, 06:17 PM | #10 |
Mentor
| Jan5-12, 10:57 PM | #11 |
Do two relativistic electrons form a non relativistic 100 MeV muon?
http://en.wikipedia.org/wiki/Muon If two relativistic electrons form a relativistic muon then a mass spectrometer will behave as if the electrons and muon have large energies when in reality maybe just the Lorentz force is weaker at high speeds. Even if the electrons and muons have classical kinetic energies at relativistic speeds, if Lorentz force weakens then they will appear deviated as if they had relativistic energies and Lorentz force were classical. However, this theory of weak Lorentz forces seen by high speed particles likely leads to contradictions or huge complications. Likely physicists took it into account but something did not work. |
| New Reply |
| Tags |
| kaufmann, relativistic energy, relativistic mass |
| Thread Tools | |
Similar Threads for: Proof of relativistic energy/mass to grow to infinity for v approaching c?
| Limits Approaching Infinity | Calculus & Beyond Homework | 12 | ||
| Limits approaching infinity | Calculus & Beyond Homework | 2 | ||
| Epsilon-Delta Proof of limit approaching infinity | Calculus & Beyond Homework | 1 | ||
| Limits Approaching Infinity | Calculus & Beyond Homework | 1 | ||
| Limit approaching infinity | Precalculus Mathematics Homework | 9 | ||
