New Reply
Thermochemistry, heat calculation.
Share Thread Thread Tools
Jan10-12, 01:59 PM   #1
When 10.00 mL of a solution of strong acid is mixed with 100.00 mL of a solution of weak base in a coffee-cup calorimeter, the temperature rises from 22.8 oC to 26.8 oC. Determine q for the acid-base reaction, assuming that the liquids have densities of 1.00 g/mL and the same heat capacities as pure water.
2. Relevant equations
total volume V=110.0mL
change in temperature delta T = 4
mass m = 110.0g
heat capacity for water C=75.291J/(mol[itex]\circ[/itex]C
q = nC[itex]\Delta[/itex]T
q = mC[itex]\Delta[/itex]T
3. The attempt at a solution
so I used the formula
because with the information given i couldn't find the number of moles and because only the molar heat capacity is given to use i had to find the mass based heat capacity and I found it to be C = 4181.3J/KgK
and then found q = 460J
which then the computer told me it was wrong.
It seemed odd that i had to go find the heat capacity rather than use the one provided. So I feel already there's my first mistake. But i know the formula is right so I can't see why it wouldn't work. However clearly my chemistry isn't that strong so perhaps I'm missing something. Any guidance would be appreciated! Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jan18-12, 07:20 AM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
How did you get 460 J for q=mcΔT when m=0.11 kg, ΔT=4 and c=4181.3 J/kgK?
ehild
New Reply
Thread Tools
Similar Threads for: Thermochemistry, heat calculation.
Thread Forum Replies
thermochemistry-heat of reaction Biology, Chemistry & Other Homework 3
Thermochemistry - work, heat, total energy Biology, Chemistry & Other Homework 0
"How much heat is evolved" Thermochemistry Question Biology, Chemistry & Other Homework 3
Thermochemistry: Heat of a Solution Biology, Chemistry & Other Homework 2
calculating the heat of vaporization of chloroform [thermochemistry] Chemistry 1
