Linear Equations (General and Standard forms: From Wikipedia)
In summary, the general form of a linear equation states that if B is nonzero, then the y-intercept is -C/B and the slope is -A/B. The standard form of a linear equation is similar, but the C value is on the opposite side of the equation. The slope of a line is defined as the change in y divided by the change in x, and for the equation Ax + By + C = 0, the slope is -A/B.
jaja1990
27
Source: http://en.wikipedia.org/wiki/Linear_equation
General form:-
It says (under the title General Form) "If B is nonzero, then the y-intercept, that is the y-coordinate of the point where the graph crosses the y-axis (where x is zero), is −C/B, and the slope of the line is −A/B."
How is the slope deduced to be -A/B?
Standard form:-
Aren't this form contradictory to the first form?
I mean, both are the same, but here C is positive, and on the left side of the equation, while in the General Form, C is positive, and on the right side of the equation.
Mathematics news on Phys.org
General form:-
How is the slope deduced to be -A/B?Standard form:-
The slope of a line is the amount that y changes if x increases by 1.
If x increases by 1, Ax increases by A, so By has to decrease by A.
More specifically if y changes by -A/B, then By changes by -A.
The second form is a new equation in which the old A, B and C no longer apply.
It is more or less related to the first form, but as you already surmised the C in the second form would have to be minus the C of the first form, if A and B are the same.
But I thought the change doesn't have to be 1 in x? What if the change is p?
The slope of a line is defined to be the change in y if x changes by 1.
If x changes by p, then y will change by p times the slope.
From Wikipedia: "The slope of a line in the plane containing the x and y axes is generally represented by the letter m, and is defined as the change in the y coordinate divided by the corresponding change in the x coordinate, between two distinct points on the line. "
That's what I meant.
"The slope of a line is the amount that y changes if x increases by 1.
If x increases by 1, Ax increases by A, so By has to decrease by A."
So, if x increases by p, Ax increase by Ap, so By has to decrease by Ap. (So, y = Ap/B).
This means -Ap/B should be the slope in general for the equation Ax + By + C = 0. Or is my conclusion wrong?
As you say, the slope is the change in the y coordinate divided by the corresponding change in the x coordinate.
Since -Ap/B is the change in y if x changes by p, that means that the slope is -Ap/B divided by p, which is -A/B.
That's right.
Thank you :)
You're welcome. :smile:
1. What is a linear equation?
A linear equation is an algebraic equation that represents a straight line when graphed. It has the general form of y = mx + b, where m is the slope of the line and b is the y-intercept.
2. What is the difference between general and standard form of a linear equation?
The general form of a linear equation is y = mx + b, where m is the slope and b is the y-intercept. The standard form is Ax + By = C, where A, B, and C are constants and A is typically positive.
3. How do you graph a linear equation?
To graph a linear equation, you can plot the y-intercept (b) on the y-axis and then use the slope (m) to find other points on the line. You can also use the slope-intercept form (y = mx + b) to graph the line.
4. What is the point-slope form of a linear equation?
The point-slope form of a linear equation is y - y1 = m(x - x1), where (x1, y1) is a given point on the line and m is the slope. This form is useful for finding the equation of a line given a point and slope.
5. How can linear equations be used in real life?
Linear equations can be used to model real-life situations that involve a constant rate of change. For example, they can be used to calculate the cost of a phone plan based on minutes used, or to determine how long it will take to travel a certain distance at a given speed.
  • General Math
  • General Math
  • Linear and Abstract Algebra
