Is 2.00 g/cm^3 Equal to 2000 kg/m^3?
  • Thread starter Thread starter jsun.12
    Density Units
2.00 g/cm^3 is indeed equal to 2000 kg/m^3. The conversion is confirmed using the relationships that 1 cm^3 equals 0.000001 m^3 and 1 kg equals 1000 g. The calculation shows that multiplying 2.00 g/cm^3 by the conversion factors yields the correct result. The discussion concludes with agreement on the accuracy of the conversion. This confirms the understanding of unit conversions in density measurements.
jsun.12
My problem is to determine whether or not my conversion is correct.
2.00 g/cm^3 is = _______ kg/m^3
If I'm not mistaken,
1 cm^3 = 0.000001 m^3
1kg = 1000g
My equation:
2.00 g/cm^3 (1kg/1000g)(1cm^3/0.000001m^3)
= 2,000 kg/m^3
Hi jsun,
the conversion is correct.
ehild
thank you!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
