| New Reply |
Is it possible to have a Mach number greater than 1 at the throat? |
Share Thread | Thread Tools |
| Mar5-12, 05:14 PM | #1 |
I have a problem for my Gas Dynamics homework, in which the problem asks to solve for the Mach number at the throat of a converging-diverging nozzle.
I assumed that the Mach at the throat should be equal to 1 since the professor said it was impossible to have a Mach number greater then 1 at the throat. After showing the same problem to a Graduate Student I work with he showed me that it is possible to have a Mach number greater then 1 at the throat through the area ratios. But after speaking to my professor a second time he has again said it is not possible. So my question is.. is it possible to have a Mach number greater than 1 at the throat. Oh the conditions for the problem are as follows: Mi=2 Ai=20 cm^2 Athroat=15cm^2 Shock Area=22 cm^2 Ae=25cm^2 where gamma= 1.4 according to the solutions Mach at the throat equals 1.662 I assumed it was 1 but it was not correct. If someone could steer me in the right direction I'd appreciate it thanks! |
| New Reply |
| Thread Tools | |
Similar Threads for: Is it possible to have a Mach number greater than 1 at the throat?
| Finding the mach number of an aircraft | Introductory Physics Homework | 3 | ||
| Why is it when I divide by a number greater than 1, I get a larger number? | General Math | 2 | ||
| Mach Number 2 | Introductory Physics Homework | 3 | ||
| Mach Number | Introductory Physics Homework | 3 | ||
| Zero Mach number lift coefficient | Engineering, Comp Sci, & Technology Homework | 1 | ||
