| New Reply |
Gas in tank exposed to a vacuum |
Share Thread |
| Mar15-12, 08:44 PM | #1 |
A tank is equally divided into two equal halves, one a vacuum and one filled with argon gas at 298K and 700 bar. The divider bursts and the gas equally disperses throughout the tank. What is the new T and P of the gas assuming argon is an ideal gas? 2. Relevant equations PV=nRT P1V1/T1=P2V2/T2 3. The attempt at a solution I assumed there was no temperature change which I am unsure of but using that logic, P=350 bar and T=298K |
| Mar16-12, 04:01 AM | #2 |
Begin with the definiton of an ideal gas. Hint: it's more than just pV = nRT.
What can you say about the dependence of U, internal energy, as a function of p,V and/or T? Then go with the first law and show that you get the same results whether the free expansion is adiabatic or isothermal or anything inbetween. |
| Mar16-12, 04:04 AM | #3 |
Begin with the definiton of an ideal gas. Hint: it's more than just pV = nRT. What can you say about the dependence of U, internal energy, as a function of p,V and/or T? Then go with the first law and determine if you get the same results whether the free expansion is adiabatic or isothermal or anything inbetween. |
| New Reply |
Similar discussions for: Gas in tank exposed to a vacuum
| Easy Tank Model? Outflow of tank proportional to volume of tank. | Engineering, Comp Sci, & Technology Homework | 8 | ||
| Differences between live tank and dead tank circuit breakers | Electrical Engineering | 0 | ||
| How to calculate water from storage tank to small tank? | General Physics | 3 | ||
| Water flow from Tank B to Tank C sizing questions | Engineering Systems & Design | 0 | ||
| Empty a gel from one tank to another tank (closed system) | Introductory Physics Homework | 0 | ||
