New Reply
Wire in an E field?
Share Thread Thread Tools
Mar17-12, 02:55 PM   #1
Wire in an E field?
If I had a current carrying wire in an E field. Would it deflect? The wire it self just has a B field and no free charge. But If I was moving with respect to the wire I would see length contraction and a net E field. So in my frame the wire would deflect. Or is something wrong with my reasoning?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Mar17-12, 04:34 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by cragar View Post
I expect it wouldn't. But let's make it more interesting, and use a length of resistance wire so there is significant potential across the wire. (Make it of carbon and delicately suspend it with elastic quartz fibres to avoid arguments.) Would it experience deflecting forces now with a few hundred volts P.D.?
I can't comment.
Mar18-12, 12:58 AM   #3
so if we have a suspended wire with a voltage across it, so There is an E field down the wire, so it is basically like a plate capacitor. So if we have a charge separation in the wire
the +q and -q charged will experience forces in the opposite directions and should cancel.
Mar18-12, 04:54 AM   #4
Recognitions:
Wire in an E field?
I think the more positive end of the wire will be pushed by the E field (i.e., attracted towards the negative plate) and the negative end of the wire will be attracted by the E field (i.e., attracted towards the positive plate), so the wire will tend to rotate about an axis through its centre.
Mar18-12, 11:37 AM   #5
So torque on an Electric dipole.
Mar19-12, 09:36 PM   #6
Now that I think more about my original post, an looking at this in the moving frame.
If I move with respect to this wire an I get a net E field from the wire, I will also get a B field from the external E field, and this will cause a Lorentz force F= q(vxB) and this will
probably balance the F=qE from the E field.
New Reply
Thread Tools
Similar Threads for: Wire in an E field?
Thread Forum Replies
Electric Field of a Straight Wire at a Particular Distance from Wire Introductory Physics Homework 1
Does constant magnetic field around a wire induce an electric field? Classical Physics 14
Current carrying wire and induced electric field within the wire Introductory Physics Homework 2
path of least resistence, static wire in B field or moveable wire? Electrical Engineering 1
Wire Loops, Current, Magnetic Field, & Straight Wire HELP! Introductory Physics Homework 1
