Resistance of DC Motor Experiment
The discussion focuses on methods to test the resistance of a DC motor, specifically addressing the concept of effective resistance. Participants suggest connecting a power supply, ammeter, and the motor in series while measuring voltage across the motor with a voltmeter to apply the R=V/I formula. They also explore the implications of back electromotive force (back EMF) and propose using a rheostat to determine the effective resistance by matching the current flow. Additionally, the importance of measuring stalled current to avoid damaging the motor is emphasized.
  • Understanding of Ohm's Law (R=V/I)
  • Knowledge of back electromotive force (back EMF)
  • Familiarity with circuit components such as ammeters, voltmeters, and rheostats
  • Basic principles of DC motors and their operation
  • Research methods to measure back EMF in DC motors
  • Learn about effective resistance in electrical circuits
  • Explore the use of rheostats for current matching in circuit experiments
  • Study the effects of stalled current on motor performance and resistance measurements
Students preparing for practical exams in electrical engineering, hobbyists working with DC motors, and educators teaching circuit analysis and motor dynamics.
bluey107
Hey all, I have a small question that's been bugging me and I can't find an answer anywhere. How do you test the resistance of a DC motor?
My main "practical" idea is to test it as you'd test any other piece of metal: connect a power supply, an ammeter and a dc motor in series, and connect a voltmeter to measure the potential difference across the motor (in parallel), then take all the readings and calculate using the R=V/I formula.
However, I thought maybe it has something to do with back emf/induced current? In this case, would I connect a galvanometer instead of an ammeter (same setup as above), start up the motor, record the reading, then hold down the motor to see the supply current, and then measure the induced current? But then, would I use the induced current, the supply current or the net current in the R=V/I calculations?
My third thought is very vague, and I have almost no backing for it, but would there be any way to measure the back emf? Because isn't that kind of the resistance of a motor?
Please help, we were just given the aim of this experiment in class and told to figure out the rest if we wanted a head start for a practical exam coming up.
Presumably you are after the "effective resistance" of the motor.
If you connected the motor and a fixed resistor in series with a given power supply [battery?] you could measure the current through the circuit.
If you then replaced the the motor with a rheostat [variable resistor], you could adjust that rheostat until the same current was flowing.
Then use what ever is necessary to measure the resistance the rheostat was set to to achieve that - should/must be the effective resistance of the motor.
If, by resistance, you mean the resistance of the wires of the motor you may be able to measre this with an ohm meter.
If you connect a battery and measure a current it must be the current when the motor is prevented from turning (stalled) you must take care to use low voltage so that you do not burn out the motor coil.
When the motor is running the current will be much less than the stalled current because of the back emf you have identified.
Once the motor is running the volts and amps tell you the power being supplied and not much about 'resistance'
  • · Replies 22 ·
9K
