Finding Transfer Functions for Mechanical Systems
The discussion focuses on deriving transfer functions for a two-body mechanical system involving equations of motion. The user has equations for two masses influenced by applied forces and spring-damper systems but struggles with the algebra needed to express the system in terms of transfer functions X1/Fapplied and X2/Fapplied. Suggestions include setting up the equations in matrix form to simplify the process. The importance of working through the algebra is emphasized, as it is essential for obtaining the transfer functions. Overall, the conversation highlights the challenges of transitioning from equations of motion to transfer functions in mechanical systems.
jrand26
Hi guys
I'm an electrical engineer and we're currently doing some control stuff which involves mechanical systems. I'm having particular trouble with a two body problem, I understand how to do the free body diagram and get the equations of motion, but I'm not sure how to get the transfer function. E.g I have, letting ' and '' be the first and second derivatives,
m1x1'' = Fapplied - k2(x1-x2) - k1x1 - c1x1'
m2x2'' = k2(x1-x2) - k3x2 - c2x2'
So now I want to get X1/Fapplied and X2/Fapplied. I'm assuming I want two equations, F = f(x1(t)) and F = f(x2(t)) so I can do the Laplace etc. My first thought was to rearrange the second equation in terms of x1 and then sub into the first equation, but the algebra seemed pretty ridiculous. Is there an easier way? I have Nise but I don't understand the method it uses, it doesn't really explain how it goes from equations of motion to transfer function (or I don't understand the method it uses). Any help is appreciated.
It sounds like you were on the right track but simply gave up because you did not want to do the algebra. There is definitely some algebra involved, so go ahead and work it through. It may be easiest if you set this up as a system of two equations in two unknowns in matrix form. It will fall right out that way.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
