Thread Closed
Please help with a uniform circular motion problem
Share Thread
Jan13-05, 12:29 PM   #1
Hey can you guys give me some help with this physics problem.. having real issues figuring it out, and ive looked all over the internet. Google'd like 100 times...
A Particle at Constant Speed A particle P travels with constant speed on a circle of radius r = 3.35 m (Figure 5-39) and completes one revolution in 20.0 s. The particle passes through O at time t = 0. State the following vectors in magnitude-angle notation (angle relative to the positive direction of x).
The picture of it...
http://www.webassign.net/hrw/166710.gif
1.) With respect to O, find the particle's position vector at the time t = 5.00 s.
answer: _________ ANGLE: 45degrees
I figured out the angle, but i cant figure out how to get the position vector. Just so u know, in case u try the problem, ive already tried the following answers, that are apparently wrong : 1.05, 4.21, .948, 5.26, and 3.35
the rest of the questions are similar to #1, so if u guys can help me with that one, i can figure out the rest.
Thanks
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jan13-05, 01:26 PM   #2
Have you drawn the picture where t=5s? In case you are looking for the magnitude of vector OP at that time, pythagoras should do it, right?
Jan13-05, 01:33 PM   #3
i did draw a picture, that really didnt do much though. I got that part of the question actually, apparently i was supposed to use the equation a (position vector0 = SqRt(ax^2+ay^2). And since it went 3.35 in the x direction, and 3.35 in the y direction, at time=5s, i got an answer of 4.74
However, I cant figure it out for when t=7.5seconds
I figured out that the angle is 67.5, and that is correct... but i cant get the position vector. I apparently need to use the formula that i used for the 1st one, but the answers i tried didnt work, can anyone help with that?
Jan13-05, 01:44 PM   #4
It's the same logic! Give a second thought to it, will ya?!
PS. This time trigonometry. :)
Jan13-05, 01:52 PM   #5
i used trig, and i tried the following answers, none of which are correct apparently:
5.3 , 5.7 , 6.6
do you get an answer different from those? I was sure that 5.3 was right but apparently its not
Jan13-05, 03:37 PM   #6
Yeah, I get 6.19. Is it correct?
I thought that the vector CP (where C is the center of the circle) forms a 45 degree angle with the x-axis and calculated how much longer than r the new y-component is.
PS. The new y-component is NOT r + r/2, which you appear to have assumed... (?)
Jan13-05, 05:58 PM   #7
This might be that Im stupid, but shouldnt the angle be 90?
Just saying 20s per cycle, 4 quadrants, 20/4=5?
Thread Closed
Similar discussions for: Please help with a uniform circular motion problem
Thread Forum Replies
uniform circular motion problem Introductory Physics Homework 8
Help on Uniform Circular Motion Problem Please! Advanced Physics Homework 1
uniform circular motion problem Introductory Physics Homework 2
Problem - Newton's second law applied to uniform circular motion Introductory Physics Homework 5
Uniform Circular Motion problem Introductory Physics Homework 2
