How Tall Can a 273.1 x 12.7 CHS Steel Column Reach with Lateral Support?
The discussion centers on the structural capacity of a 273.1 x 12.7 CHS steel column when laterally supported every meter. It concludes that this column can theoretically reach a height of approximately 3.9 kilometers without buckling, while a self-supported design would limit the height to around 2.5 kilometers due to its own weight. The conversation also explores the potential applications of this design in constructing yacht masts, earthquake-resistant buildings, and bridges. Participants emphasize the importance of using finite element (FE) analysis for validation and optimization of the proposed structural system.
  • Understanding of structural steel design principles
  • Familiarity with hollow structural sections (HSS)
  • Knowledge of finite element analysis (FEA) software
  • Basic concepts of lateral support in structural engineering
  • Research the design capacity tables for structural steel hollow sections
  • Learn about finite element analysis (FEA) tools like ANSYS or Abaqus
  • Explore the concept of self-braced lattice columns and their applications
  • Investigate the structural implications of webbing in large diameter tubing
Structural engineers, architects, and construction professionals interested in innovative design solutions for tall structures and their applications in various construction projects.
davidratcliff6255
I have recently came across design capacity tables for structural steel (hollow sections). - In the table it shows that 273.1 x 12.7 CHS will not buckle at 1 metre of height (below that, size 219.1 x 12.7 at the same height will buckle at 10 kN less than full capacity if it were fully supported)... So if a continuous vertical length of size 273.1 x 12.7 tubing were laterally supported every 1 metre, the tubing should reach full height of around 3.9 km, right?
I have figured out the webbing method of that size tubing to be around 35% extra (self supported) weight... so works out to be somewhere around 2.5 km total height before it will squash from its own weight. - Smaller diamater = more webbing, larger diamater = less webbing. So if a large enough diamater were used you could probably get the webbing down to around 10% of the weight of the tubing... So around 3.5 km uniform section.
I am seeking input from anyone with access to (FE) computer analysis program who would be interested in doing a test with me. If I am right then the system could be used for anything from a yacht/ship mast to an, earthquake proofing, highrise building "spine" system... which could also double as the crane used for heavy lifting during construction. With a couple of simple changes can also be used for bridges.
Regards,
Dave
If you extend your concept a little further you will put holes in the webs and create what is a self braced lattice column or tower, as is used for construction cranes, electricity transmission pylons and communication towers.
https://en.wikipedia.org/wiki/Tokyo_Skytree
