Solving an Object Falling with Non-Linear Power Series ODEs
Euler1707
I have not had luck in finding a solution that describes an object falling. Forces include gravitational force which is constant and a vicous force directly proportional to the cube of the velocity. I am supposed to find v as a function of time.
v' + a(v)^3 = b where a and b are constants.
I have a lot of paper crumbled on the floor. I might add that I am just doing this for fun. I am practicing and learning some math. It is my hobby. :)
If you are attempting a power series solution, why don't you tell us what your guess for the series is, and what the ODE looks like after substituting in the series?
Well,
I have attempted to guessv = \Sigmac_{n}t ^{n}
But my problem is the cubed term. Series solutions seem to only be easy when dealing with polynomial coefficients, but this time the dependent variable is causing the non-linearity of the ODE.
I have ofcourse substituted the derivative terms of the power series but I do not know how to cube the series in order to then find the coefficients. Cubing the series would result in a mess.
Thanks for any input.By the way this problem is from an OLD book in mechanics. Very cool read if anyone is interested
Slater and Frank Mechanics 1947.
Your equation should be:
<br /> m \, \dot{v} = m \, g - k \, v^3<br />
It is a 1st order ODE in velocity! The one you have is 2nd order. If you introduce dimensionless variables for time and velocity:
<br /> t = a \, x, v = b \, y, \ y = y(x)<br />
then, the equation reduces to:
<br /> m \, \frac{b}{a} \, y&#039;(x) = m \, g - k \, b^3 \, y^3<br />
Let us choose a, and b so that:
<br /> m \, \frac{b}{a} = m \, g = k \, b^3<br />
<br /> a = \left( \frac{m}{k \, g^2} \right)^{\frac{1}{3}}, \ b = \left( \frac{m \, g}{k} \right)^{\frac{1}{3}}<br />
then the ODE simplifies in form:
<br /> y&#039; = 1 - y^3<br />
This equation is with separable variables:
<br /> \frac{dy}{1 - y^3} = dx<br />
Integrating:
<br /> \int_{y_0}^{y}{\frac{dy&#039;}{1 - (y&#039;)^3}} = x, \ y(x = 0) = y_0<br />
Do the partial fraction decomposition:
<br /> \frac{1}{1 - (y&#039;)^3} = \frac{1}{(1 - y&#039;) (1 + y&#039; + (y&#039;)^2)} = \frac{A}{1 - y&#039;} + \frac{B \, y&#039; + C}{1 + y&#039; + (y&#039;)^2}<br />
<br /> 1 = A (1 + y&#039; + (y&#039;)^2) + (B \, y&#039; + C)(1 - y&#039;)<br />
<br /> 1 = (A + C) + (A + B - C) \, y&#039; + (A - B) \, (y&#039;)^2<br />
<br /> \left\lbrace\begin{array}{lcl}<br /> A + C &amp; = &amp; 1 \\<br /> A + B - C &amp; = &amp; 0 \\<br /> A - B &amp; = &amp; 0<br /> \end{array} \right. \Leftrightarrow A = \frac{1}{3} \, B = \frac{1}{3} \, C = \frac{2}{3}<br />
Thus, you have the integrals:
<br /> \frac{1}{3} \, \int_{y_0}^{y}{\frac{dy&#039;}{1 - y&#039;}} + \frac{1}{3} \, \int_{y_0}^{y}{dy&#039; \, \frac{y&#039; + 2}{1 + y&#039; + (y&#039;)^2}} = x<br />
Do the integrals (assuming 0 \le y, \ y_0 &lt; 1
Thank you
Your solution is very elegant. Although the book calls for a power series solution ( at least first 4 terms). I was reviewing from my ODE books but like always math books turn out not to have the thing you are looking for. hehe
Nevertheless thanks for taking the time to solve it.
Also yeah, I did realized that I got carried away with the primes. Ofcourse the physical description was enough to figure it out.
Oh, I think I might have found a better method that involves a polynomial solution. Maybe just by iteration using the Taylor series. The problem does not say anything about I.C s but I cannot think of anything else. xD
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
