Whats is volume of mass at the centre of the sun
In summary, the volume of mass at the center of the sun is 3.805 x 10^25 cubic meters, with fusion occurring at a rate of 9.2 x 10^37 times per second and a mass fusion reaction rate of 6.155 x 10^11 kilograms per second. This amount of mass would take up one-third of the present volume of the sun.
karen_lorr
63
Thank you
Astronomy news on Phys.org
Whats is volume of mass at the center of the sun?
Total solar radius:
[tex]R_{\odot} = 6.955 \cdot 10^8 \; \text{m}[/tex]
Inside 24% of the Sun's radius, 99% of the power has been generated, and by 30% of the radius, fusion has stopped nearly entirely.
Active solar core fusion radius:
[tex]r_f = 0.3 R_{\odot}[/tex]
Average active fusion core volume:
[tex]V_f = \frac{4 \pi r_f^3}{3} = 3.805 \cdot 10^{25} \; \text{m}^3[/tex]
[tex]\boxed{V_f = 3.805 \cdot 10^{25} \; \text{m}^3}[/tex]
I am trying to get a visualization of dimension of a certain amount of mass within the core of the sun?
The proton–proton chain occurs around 9.2×10^37 times each second in the core of the Sun. This reaction uses four free protons (hydrogen nuclei).
Solar core fusion reaction rate:
[tex]\frac{dn}{dt} = 9.2 \cdot 10^{37} \; \frac{\text{fusions}}{\text{s}}[/tex]
Solar mass fusion reaction rate:
[tex]\frac{dm}{dt} = 4 m_p \frac{dn}{dt} = 6.155 \cdot 10^{11} \; \frac{\text{kg}}{\text{s}}[/tex]
[tex]m_p - \; \text{proton mass}[/tex]
[tex]\boxed{\frac{dm}{dt} = 6.155 \cdot 10^{11} \; \frac{\text{kg}}{\text{s}}}[/tex]
But if you could "see" it, how much space would this lot take up.
One-third the present volume of the Sun.
Reference:
Solar - core - Wikipedia
Simple nitpick: one third radius = 1/27 volume, or .3 radius -> .027 volume.
Still pretty large. I would have guessed much smaller.
Jim Graber
What is volume of mass at the centre of the sun?
The volume of mass at the centre of the sun is approximately 1.3 million times that of Earth.
How is the volume of mass at the centre of the sun calculated?
The volume of mass at the centre of the sun is calculated using the formula for the volume of a sphere: 4/3 x π x r^3, where r is the radius of the sun.
What is the mass at the centre of the sun composed of?
The mass at the centre of the sun is primarily composed of hydrogen and helium, which make up about 98% of its total mass.
Does the volume of mass at the centre of the sun change over time?
The volume of mass at the centre of the sun does not change significantly over time. However, due to nuclear fusion reactions, the mass and density may vary slightly.
What is the temperature of the mass at the centre of the sun?
The temperature at the centre of the sun is estimated to be around 15 million degrees Celsius, making it incredibly hot and dense.
  • Astronomy and Astrophysics
