| New Reply |
Deflection vs. Bending in a Beam |
Share Thread | Thread Tools |
| May31-12, 05:56 PM | #1 |
Problem:
![]() What is the equation that relates properties of a metal (modulus of elasticity, yield strength, elongation, etc) to how far it can deflect before permanently being bent. I can calculate how far a beam will deflect under different loading and support but I just don't know what the limit is until it won't bounce back to it's original state again. I'm looking at 6061-T6 aluminum. I've found two different equations online: σ = F/A F = EI∏^2 / (KL)^2 I want to say it's σ = F/A but I would think that orientation of the beam would matter. It would be easier to bend it about it's width than it's height. I would also think that in this case, if B was longer it would require a smaller P value to bend the beam. I'm trying to teach myself this stuff for a project and I won't be learning it in college classes until Fall quarter so any help will be appreciated! Thanks |
| May31-12, 09:11 PM | #2 |
Those equations you cite apply to axial forces and stresses, and critical buckling loads. Axial loads act along the direction of the beam, and either elongate or compress it. But you don't have axial loads, you have loads applied perpendicular to the beam, causing bending moments and bending stresses and beam deflections. you'll have to learn how to calculate the max bending moment in the beam, and from that, the max stress in the beams outer fibers. the beam will be slightly permanently deformed when the max stress reaches the yield stress of the given material. Calculating the max deflwection is a bit more difficult, because it involves the use of calculus or 'beam' tables. You don't learn these things overnight.
| May31-12, 11:23 PM | #3 |
I have the beam tables, and I've gone through Calc 4 so throw anything relevant my way and I'll see if I can get it.
Here's what I have: http://uploading.com/files/ab5m1512/..._Formulae.pdf/ |
| Jun1-12, 09:59 AM | #4 |
I cant open your file, but it likely should indicate that the max moment is at the first pin support and equal to P (B - A) in your example. So knowing the max moment, what is the max bending stress?
| Jun1-12, 12:43 PM | #5 |
Sorry, here: http://i.imgur.com/jfqU6.png
P(B-A), the area would be WH but there is more moment at the edges of the beam than towards the center, so it would be: P(B-A)(H/2) but then it would be on a line of material and not an area. So P(B-A)(H/2)/(W) ? Moment of force P on the outer fibers per length? |
| Jun1-12, 02:50 PM | #6 |
You need to grasp the basics before using tables. |
| Jun1-12, 08:23 PM | #7 |
| Jun2-12, 06:48 AM | #8 |
Try a web search on Strength of Materials.
| Jun2-12, 10:16 AM | #9 |
What you are looking for is a combination of Hooke's law and the flexure formula for elastic bending. The application of Hooke's law to a beam is only valid when the beam behaves elastically, meaning that following the removal of forces, the beam will return to its original shape and position. Knowing this, the beam only will behave elastically in a region below what is called the proportional limit which is the maximum normal stress/strain for the elastic region. Anywhere above this is considered the plastic region where Hooke's law doesn't apply because Hooke's law relies on the linear relationship between stress and strain in the beam. Typically, published values of the proportional limit are hard to come by, however the proportional limit is generally approximately equal to the yield strength of the material, which published values are easily available. So essentially you are looking for the yield strength of 6061-T6 Al, which I can find as 35,000 psi (241 MPa). If you set this equal to the stress in the flexure formula, σ = Mc/I, you can solve for the maximum moment allowed. However, since you are looking at a simply supported beam, the bending moment is variable across the beam as described by a second order differential equation with the initial conditions being specified by both the supports and loading. The tables you have listed are only specified for simply supported beams with the supports at the end points, meaning you will have to solve the differential equation yourself.
| Jun3-12, 02:10 AM | #10 |
Thank you cmmcnamara, that was extremely helpful. I got it figured out now. All starting to make sense.
| New Reply |
| Thread Tools | |
Similar Threads for: Deflection vs. Bending in a Beam
| bending and deflection of composite beam | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Beam bending problem, calculate deflection of a beam | Engineering, Comp Sci, & Technology Homework | 7 | ||
| Beam deflection in a cantilever beam | Mechanical Engineering | 3 | ||
| bending for beam -- deflection | Engineering, Comp Sci, & Technology Homework | 5 | ||
