vanhees71 said:
The conformal transformation is defined by
{x'}^{\mu}=x^{\mu}, \quad g_{\mu \nu}'(x)=\Omega^2(x) g_{\mu \nu}.
This is called Weyl re-scaling of the metric. The conformal group is a lot bigger than Weyl transformation:
(1) In Minkowski space \mathbb{R}^{1}\times \mathbb{R}^{n-1}, Poincare’ transformation,
\{L(\Lambda),T(a)\}: \ \bar{x} = \Lambda x + a,
is a conformal map with the conformal factor,
<br />
\Omega^{2}(x) \equiv (\det |\frac{\partial \bar{x}}{\partial x}|)^{\frac{2}{n}}= 1.<br />
This means that Poincare’ transformations form the isometry group ISO(1,n-1) of \mathbb{R}^{1}\times \mathbb{R}^{n-1}.
(2) An inversion of the coordinates,
I: \ \bar{x} = \frac{x}{x^{2}},
\Omega^{2}(x) = \frac{1}{x^{2}}.
On \mathbb{R}^{1} \times \mathbb{R}^{n-1} with n > 2, all possible conformal transformations (i.e., the whole conformal group C(1,n-1) \simeq SO(2,n)/Z_{2}) can be generated using only (1) and (2). Indeed, the conformal group C(1,n-1) is the smallest group containing the isometry group ISO(1,n-1) and the inversion I.
The proof consists of two parts;
(i) It is almost trivial to see that the combination
<br />
K(c) \equiv I T(c) I: \ \bar{x} = \frac{x + c x^{2}}{1 + 2 c.x + c^{2}x^{2}},<br />
generates a conformal map with
\Omega^{2}(x) = (1 + 2c.x + c^{2}x^{2})^{-2}.
The transformation K(c) is called a “conformal boosts” or “special conformal transformation”. The latter name was first coined by H.A. Kastrup in 1966.
(ii) It is rather tedious but straightforward to show that the combination
<br />
D(\frac{1}{1+c^{2}})\equiv T(\frac{-c}{1+c^{2}})K(c)T(c)K(\frac{-c}{1+c^{2}}),<br />
generates dilatation,
D(\lambda): \ \bar{x}= \lambda x.
Dilatation is a conformal map with the conformal factor
\Omega^{2}(x) = \lambda^{2}.
Then it's easy to see that A_{\text{em}} is invariant under conformal transformations, when we assume that
A_{\mu}'(x)=A_{\mu}(x)
under conformal transformations. Then also
F_{\mu \nu}'(x)=F_{\mu \nu}(x) \; \Rightarrow \; {F'}^{\mu \nu}(x) = \Omega^4(x) F^{\mu \nu}.
Under the conformal group, a (Lorentz) vector field of weight d transforms according to
<br />
\bar{A}^{a}(\bar{x}) = |\frac{\partial \bar{x}}{\partial x}|^{\frac{d-1}{n}}\frac{\partial \bar{x}^{a}}{\partial x^{c}}A^{c}(x).<br />
In general, spinor tensor field in the (j_{1},j_{2}) representation of the Lorentz group SL(2,\mathbb{C}), transforms in the (d, j_{1},j_{2}) representation of the conformal group SU(2,2);
<br />
\delta \Phi^{(d,j_{1},j_{2})}(x) = \left(-f^{a}\partial_{a} + \frac{1}{2}\partial^{[a}f^{b]}\Sigma_{ab}^{(j_{1},j_{2})} + \frac{d}{4}\partial_{a}f^{a}\right) \Phi^{(d,j_{1},j_{2})}(x),<br />
where,
f^{b}(x) = a^{b} + \omega^{b}{}_{c}x^{c} + \alpha x^{b} + 2(c.x)x^{b}+ c^{b}x^{2},
is the conformal Killing vector.
Sam
