Bit of confusion with coils and electromagnetic induction
The discussion clarifies that for electromotive force (emf) to be induced in a coil, the magnetic field must act perpendicular to the coil's face. If the coil moves sideways through the magnetic field, rather than along its length, emf can be induced. However, when the coil is entirely within a uniform magnetic field, the flux linkage remains constant, resulting in zero induced emf. This holds true unless the coil rotates, which would change the flux and induce emf.
  • Understanding of electromagnetic induction principles
  • Familiarity with the concept of magnetic flux
  • Knowledge of coil orientation and movement in magnetic fields
  • Basic grasp of Faraday's law of induction
  • Study Faraday's Law of Electromagnetic Induction in detail
  • Explore the effects of coil rotation on induced emf
  • Investigate the behavior of magnetic fields and flux linkage
  • Learn about applications of electromagnetic induction in real-world devices
Students of physics, electrical engineers, and anyone interested in understanding the principles of electromagnetic induction and its practical applications.
curiousjoe94
Apparently for emf to be induced in a coil, the magnetic field (or part of it) has to act along the normal to the coil face. So does this mean that the coil moves side-ways through the magnetic field? where instead of moving through its length (its longer side), it moves through the coil face width. I've attached a picture below to show what I mean by this.It says in my book as well, that 'When the coil is completely in the field, the flux linkage does not change, so the induced emf is zero. So does this mean that in my diagram below, as soon as the coil has fully in between those two magnets, induced emf stops completely? - even if the coil continues to move up/down within the magnetic field?(by the way, the picture is from a bird's eye view)
hi curiousjoe94! :smile:
if the magnetic field is uniform and constant, yes …
unless the coil rotates, the flux through it cannot change, and the induced emf is zero
