Calculating the volume of gas in the same canister from 2 locations.
  • Thread starter Thread starter LAB
    Gas Volume
The discussion revolves around calculating the volume of gas in a canister after it has been transported from one location to another with different atmospheric conditions. The ideal gas law (PV=nRT) is used to determine the number of moles of gas and the expected volume at the new location, which was calculated to be approximately 154mL less than at the original location. However, a physical measurement indicated a much larger discrepancy of 700mL. Possible explanations for this difference include gas leakage during transport or improper sealing of the canister, particularly if it was transported by air where pressure changes could affect the gas volume. The conversation highlights the complexities of gas behavior under varying environmental conditions.
LAB
I have a canister with a capacity of 8334cm3, if the canister is sealed at ambient atmospheric pressure (1016.5hPa, 25.6 deg/C) at one location then transported thousands of kilometres where the ambient pressure and temperature (1014.5hPa, 20.5 deg/C) is different.
I then connected my canister to an inverted measuring cylinder over a water bath to physically measure the difference in the volume of gas in the canister, I got a reading of -700mL (started at 1000mL finished at 300mL).
How do I mathematically calculate the difference in volume of gas in the canister in mL's ?
You'd use the ideal gas law, PV=nRT
P is pressure, V is volume, n is number of molecules of substance in mols, R is the ideal gas constant (8.31 J/mol K) and T is Temperature (in Kelvin).
From the parameters you measured, you can rearrange the equation to determine the number of mols of substance in your container.
n=(PV)/(RT)
If you then want to know the volume of that container for a given pressure and temperature, you can again rearrange the equation:
V=(nRT)/P
and as long as the container remains sealed, n should remain constant.
However, this does assume that no gas was able to permeate your container (which is nearly impossible in reality).
Thank you Nessdude14,
After doing the calculation according to the Ideal Gas Laws sugested, the volume of gas at location 2 with lower temperature and pressure equals ~154mL less than location 1, but when I physically measured it; the result was 700mL less.
Can anyone sugest why this is happened? or did I calculate it in correctly?
How was the gas transported and in what?
If by air then gas might have leaked out due to the reduced cabin/hold pressure in flight. As you descended the increasing pressure might have resealed the container (eg gas inside now stuck at the lower cabin pressure). Hence much lower volume when measured.
If the canister is a special gas bottle then this is unlikely to be the cause - unless it wasn't sealed properly?
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
