EFFECT OF Air PRESSURE ON WEIGHT
The discussion revolves around the effect of air pressure on the weight of objects, particularly focusing on the concepts of buoyancy and the balance of forces due to atmospheric pressure. Participants explore how upward thrust from air and atmospheric pressure interact to influence perceived weight.
  • Some participants suggest that the upward thrust of air reduces the weight of an object, questioning how atmospheric pressure might increase weight.
  • Others clarify that the upward thrust, or buoyancy, results from the pressure difference between the bottom and top of an object, which is more pronounced in denser fluids like water compared to air.
  • One participant notes that for pressure to affect weight, it would need to be constrained to act downward without upward influence, which is not the case with typical balances.
  • There is a discussion about the balance of pressures, with some arguing that while pressure above pushes down, pressure below pushes up, leading to a net decrease in weight due to slightly greater pressure from below.
  • Another participant mentions that higher ambient air pressure increases air density, which could slightly enhance buoyancy effects.
Participants generally agree that air pressure has effects in both upward and downward directions, but there is no consensus on whether atmospheric pressure increases weight or if it primarily contributes to buoyancy effects that reduce perceived weight.
Discussions include assumptions about the nature of weight and buoyancy, as well as the conditions under which pressure effects are considered. The interplay between atmospheric pressure and buoyancy remains nuanced and unresolved.
bhallagsm
I have learned that due to upward thrust of air, the weight of an object is reduced to some extent than the real weight. What about of the effect of air pressure or atmospheric pressure on weight? Should it not result in increase in weight?
"upward thrust"?
If an object moves upwards, air can move downwards - the change in potential energy in the system is less than the change in a vacuum. This looks like a reduced weight.
I think that was buoyancy.
In order for the pressure itself to have an effect, it would have to be constrained to push down on the scale but not up. Balances don't have vacuums underneath them.
The air surrounding an object is pressing in all around it. The pressure underneath (up) is slightly more than the pressure at the top (down) so this results in a net upthrust. It's just the same as for an object in water but the effect is much more noticeable.
If you try to lift an object with a very smooth bottom from a smooth surface, air can't get in underneath and you get the full effect of atmospheric pressure from above but none from below. Until the air leaks in underneath, you need a massive effort to lift it.
yes...because water is so much more dense than air.
Also, as a note, there is no 'real weight' of an object...it's weight depends on where you measure it...weight in water is different from weight in air which is different from planet to plant, for example.
Mass is constant...Weight = mass x gravity which is a form of F = ma.
of course the upward thrust of air reduces the weight. But what about the air pressure above us? Does it not increase the weight?
There is pressure above you pushing down and trying to increase your weight, but there is just as much pressure below you pushing up trying to decrease your weight. So they ALMOST balance out. But, there's actually slightly more air pressure below you than above you, so the overall total effect is that your weight actually gets decreased. This is the "upward thrust" you speak of, otherwise known as buoyancy. It takes the pressure above you into account.
"Of course" there is an effect of pressure in both directions. However, because pressure increases with depth, there is more upward force than downward force. Hence, upthrust.
[Edit: snap!]
When ambient air pressure is higher (for a given temperature), the density of the air will be higher, so buoyancy will be increased - just slightly.
Thanks , for appropriate explanation
  • · Replies 27 ·
  • · Replies 31 ·
  • · Replies 50 ·
  • · Replies 16 ·
