Understanding the Probability of Measuring an Allowed Energy in a Wave Function
The discussion revolves around the interpretation of energy measurements in quantum mechanics, particularly in the context of wave functions in an infinite square well. Participants explore the implications of measuring allowed energy values and the subsequent behavior of the wave function, including the concepts of stationary states and the uncertainty principle.
  • Some participants assert that measuring an allowed energy En collapses the wave function into the nth stationary state, suggesting that all subsequent measurements will yield that same energy.
  • Others argue that this interpretation conflicts with the idea that a wave function could "delocalize" in energy space after measurement.
  • One participant mentions that the expectation value of energy can be a non-allowed value, drawing an analogy to the mean value of a die roll.
  • Concerns are raised about whether measuring energy repeatedly would violate the uncertainty principle, particularly the delta E delta t relation.
  • Participants discuss the conditions under which a measurement can be considered "pure" and whether real-world measurements can achieve this without perturbation.
  • Examples are proposed, such as measuring the wavelength of a photon emitted from an electron, to illustrate potential "pure" energy measurements.
  • Some participants highlight that in real-world scenarios, particles are not perfectly isolated, which complicates the interpretation of stationary states.
Participants express differing views on the implications of energy measurements and the behavior of wave functions post-measurement. There is no consensus on whether measuring energy leads to a definitive stationary state or if it allows for subsequent non-allowed energy values.
Participants acknowledge that real-world scenarios introduce complexities that may not align with theoretical models, such as the infinite square well. The discussion reflects uncertainty regarding the conditions under which measurements can be considered unperturbative.
DocZaius
In Griffiths' page 36/37 he says "As we'll see in Chapter 3, what |Cn|^2 tells you is the probability that a measurement of the energy would yield the value En (a competent measurement will always return one of the "allowed" values - hence the name - and |Cn|^2 is the probability of getting the particular value En."
This statement comes at the end of the infinite square well section and it concerns any sum of stationary states.
Wouldn't measuring one of the allowed energies "En", mean collapsing the wave function into the nth stationary state (and that state only!)? Doesn't that mean that the wave function has then assumed a single stationary state, thereby guaranteeing all subsequent energy measurements of the wave function to yield that particular En?
This seems to disagree with my intuition about what happens to a wave function after measurement (that it would "delocalize" in energy space) and it disagrees with my professor's interpretation who literally takes issue with the statement that an energy measurement must yield one of the allowed values. He says that it can yield any value, and that a mix/sum of specific n states are responsible for returning a non-"allowed" En.
Yes.
I always liked the saying, "the great thing about physical intuition is that it can be adjusted to fit the facts."
The *expectation value* of energy can be a non-allowed value. This is the same as the fact that the expected (mean) value of a six-sided die is 3.5. But you'll always get an integer if you roll the die.
So just to be clear - once I measure the energy of my infinite square well wave function, I have set it into a stationary state corresponding to that allowed energy and it will remain there subsequently? All future measurements, for all time, of the energy of that wave function will be my first energy measurement? Doesn't that violate some version of the uncertainty principle? The delta E delta t one?
This very much disagrees with my professor so I want to make sure! And I understand your point about the expectation value but we were talking about an actual single measurement.
Yes, as long as you don't disturb the system by doing something other than an energy measurement.
No, it's a consequence of the energy-time uncertainty principle. Griffiths has an explanation of the meaning of this uncertainty relation; have you read it?
The idea is that (delta E)(delta T) ~ hbar, where (delta E) is the spread in energy and (delta T) is some measure of the characteristic time over which the system changes. If we reduce (delta E) to zero, then (delta T) must go to infinity; that is, it takes infinitely long for the system to undergo any changes; that is, the system never changes. Of course, this is why we call energy eigenstates "stationary states"!
So all one needs to do to create a wave function that is exactly one stationary state is to create any wave function at all first (which is going to be a sum of stationary states), then measure its energy. Now you have a very simple single function of time and space rather than a sum of many. Can you give an example of an energy measurement in the real world which might be unperturbative enough to be a "pure" energy measurement?
What about measuring the wavelength of a photon emitted from an electron. If a specific allowed jump in energy of an electron caused this photon to be emitted, might not my measurement of that photon's wavelength be considered a "pure" energy measurement of the electron? Would that very measurement of the photon not put the electron in a stationary state? I am of course assuming that one could express the wave function of an electron as a sum of stationary states, which assumes that the time dependent Schrödinger equation of the electron (in some potential) would be separable, which is not necessarily true.
To prepare a photon in a highly precise energy state you can use an optical cavity: http://en.wikipedia.org/wiki/Optical_cavity
An optical cavity consists of a pair of partially transparent mirrors separated by a certain distance. If you shoot a photon at it, it will only pass through if it has a wavelength (thus energy) in a very narrow range. You can think of this as an energy measurement measurement than detects whether the photon has a certain energy or not.
A problem with thinking about stationary states of real-world electrons is that the only stationary state of an electron in an actual atom is the ground state. The excited states aren't pure energy eigenstates: they have a finite lifetime, after which they transition to the ground state + a photon, so they aren't stationary.
You should make sure that you are not misunderstanding your prof. In any real world situation, the particle will not be perfectly isolated and there is no infinite well, so over time outside influences will cause the state to evolve from the stationary state. However, in the theoretical perfect world of the infinite square well, a perfect measurement will leave the particle in a fixed state.
Whenever real world situation come in, there will be many complications to this, but don't confuse those complications with the fundamental theory.
There are more complicated situations when it comes to a measurement of the energy, but a measurement that gives you zero uncertainty for the energy of a single particle will necessarily be an eigenvalue of the state.
  • · Replies 32 ·
  • · Replies 25 ·
  • · Replies 24 ·
  • · Replies 36 ·
10K
  • · Replies 18 ·
